Old 03-20-2023, 11:59 AM   #1
ctrlz
Has anyone had an oil pump failure running 5W-30?
Where I'm going with this is that I think heavier weight oils (e.g. 0W-40) may be implicated in oil pump failures.
The long-winded background info:
1) The pictures of a damaged pump show a cracked stator as seen in the below link. I believe this favors an internal cause of the damage.
https://www.camaro6.com/forums/showp...4&postcount=13
The Katech aftermarket pump uses different material for the stator.
2) I believe the problem may be pump cavitation, which is caused when a pump is starved on the inlet (suction) side, and vacuum pockets ("bubbles") form within the pump. When these collapse, it creates damaging forces and vibration.
3) Our pump (shared by LT1 and LT4) was initially developed for the Chevy Cruze to improve fuel economy. Estimate in that car was about 3% mpg improvement. Recommended oil for Chevy Cruze is 5W-30.
4) An oil pump is more likely to cavitate with higher viscosity oil (slower drainback, lower velocity in pump suction line)
5) 0W-40 is more viscous than 5W-30 at all temps. Despite the "0W" winter designation, this ends up being true.
6) The LT4 has modifications to the "oil passages" to "improve drainback." I put that in quotes because that is the level of specific detail provided by GM. Suffice to say, the LT4 must have had some issues requiring modification.
7) LT4's seem to have the most reports of oil pump failures on Camaro6
Old 03-20-2023, 01:54 PM   #2
Mark R
Drives: 2018 ZL-1
If the oil pump is so weak that slight viscosity differences in oil will make or break an oil pump, it needs to be replaced. It's too weak.
We can all debate the real cause of the problem until the cows come home, and probably never know for sure. It really does not matter. The harsh reality with the ZL-1 is that if you don't want to suffer an oil pump failure, you need to get it replaced with the only one offered on the aftermarket: Katech.
Old 03-20-2023, 01:59 PM   #3
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Track guide says to run 15W50.. so i dont buy 0w40 being cause.
ing for grip.
http://www.motorsportsne.com/
Old 03-20-2023, 09:28 PM   #4
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
I run 5W30 synthetic in my ZL1 and haven’t had any issues so far at almost 25,000 miles. I use Lucas oil and either a Mobil 1 or Napa Gold oil filter.
Old 03-21-2023, 09:51 AM   #5
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
In a stock engine I see no reason to deviate from synthetic 5w30. In a modified LS/LT engine that has a cam and modified valve train I would run Castrol Edge 5w50 or Mobil 1 15w50. I don't see oil viscosity causing oil pump failures. I can see it causing valve train issues because of the lifter oil passages not being designed for heavier weight oils... causing starvation to the top end of the engine.
Old 03-21-2023, 11:21 AM   #6
JSH
JSH's Avatar
Drives: '20 ZLE
... In a modified LS/LT engine that has a cam and modified valve train I would run Castrol Edge 5w50 or Mobil 1 15w50.
Interesting. I haven't used either of those. I've been using Mobil 1 5W30 for some time and it doesn't use a drop, but it does consume a bunch of 0W40. I think I have some 50 weight oil in my garage.
2020 ZL1LE A10.
LME LT4 390 short block, CID Heads, Kong E2650, FBO.
15" conversion, Nitto 555Rii or MT ET Street R or Toyo Proxes RR.
100 octane: 1045hp/1055tq.
100 octane + Alky MAF Meth (1) 10+:
Old 03-23-2023, 10:34 PM   #7
Scraps0f
Drives: 2018 NGM ZL1
I have been running Mobile1 ESP Synthetic, 0W40 since I changed my oil after break in period. I am in WNY and only drive in the warmer months, and have about 30k miles on my ZL1. Never have I seen any issues in oil pressure. Nor have I experienced any burn off. Hopefully it stays that way.
Scraps0f is offline   Reply With Quote
Old 03-25-2023, 03:24 AM   #8
articblueSS
Drives: 2018 ABM 1SS 6M
My oil pump failed at 20k miles. I’ve always run 5w30 oil in it.
2018 1SS 6M ABM
articblueSS is offline   Reply With Quote
Old 03-25-2023, 08:12 AM   #9
ctrlz
Well, there you go.
What was the situation? Tracking, hard use, or just normal driving and it went?
Old 03-25-2023, 08:14 PM   #10
articblueSS
Funny you ask! The car is my daily driver. I’ve never tracked it or driven it hard at all. I haven’t even done a burnout! Ironically, this just happened this past week. The car is currently at the dealership and I’m told I should have it back in a week or so.
2018 1SS 6M ABM
Old 03-25-2023, 11:31 PM   #11
Val Walkinshaw
L8ap3x
Val Walkinshaw's Avatar
Drives: 2018 2SS 1LE
My manual says 5w-30. So outside of track days where it says 0-40, I always run 5w-30.
Top end issues are more likely the result of running the wrong viscosity. Aka premature failure.
Remember 5 is for winter and how thick it is at winter temps.
30 is less viscous/less thick at high temps compared to 40. Location and heat play a factor here.
"Manuals win hearts. Automatics win races."
2018 2SS 1LE HBM 6M
Val Walkinshaw is offline   Reply With Quote
Old 03-25-2023, 11:36 PM   #12
Let us know what they find. As I said in the other thread, your failure looks substantially different from all those other LT4 pump failures.
Old 03-26-2023, 10:36 AM   #13
ctrlz
The reality is the "warm" number has bearing on the "winter" viscosity.
When cold, 0W-40 is more viscous than 5W-30. I will find a link and add to this post later.
Old 03-26-2023, 10:42 AM   #14
N Camarolina
N Camarolina's Avatar
Drives: 2021 2SS 1LE
I'll look forward to that. I incorrectly assumed that these oil weight ratings were absolute (0W always < 5W) and corresponding to a particular, fixed viscosity. If what you say is correct, then that 5W-50r would presumably be thicker cold than 5W-30 and therefore not an acceptable choice for an LT1.
N Camarolina is offline   Reply With Quote
