Old 03-19-2023, 02:22 PM   #1
ironfang
Drives: 2018 Camaro 2SS
Starting the 6.2L
How many cranks does it take your SS to start?
I just got a 2018 a week ago and it felt like maybe 2-3 revolutions
Yesterday and today it feels like 5-6?
ironfang is offline   Reply With Quote
Old 03-19-2023, 03:17 PM   #2
rcinsolo
Drives: 2023 Camaro 1SS 6 speed convertible
My 2023 takes 3 or 4. Depending on last time it was driven and outside temperature.
rcinsolo is offline   Reply With Quote
Old 03-19-2023, 03:24 PM   #3
Casper the friendly G
Drives: 17' Chevy Kamaro SS 6 speed
Depends...sometimes just one or two on a cold start, then another day cold start maybe 3or 4. Bottom line it always starts.
Casper the friendly G is offline   Reply With Quote
Old 03-19-2023, 06:14 PM   #4
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
If you are talking a cold start - it can vary. The high pressure fuel pump is mechanically driven by a lobe on the camshaft. The engine will turn over without the ecu firing the injectors and the spark plugs until the fuel rails hit the right psi needed by the injectors (something like 2200 psi). So, the longer cranks are there when needed to hit the psi target. Bottom line - normal operation.
476 rwhp/440 rwtq (sold)
Old 03-19-2023, 08:34 PM   #5
pzoom
pzoom's Avatar
Drives: 2021 SS 1LE SHOCK
Newer cars also have several conditions (from sensors) that have to be met before it fires due to emissions. It’s not like older cars that need fuel and spark.
pzoom is offline   Reply With Quote
Old 03-19-2023, 09:34 PM   #6
FlukeSS
FlukeSS's Avatar
Drives: 2020 Camaro 2SS A10
E85 + Cold Weather, 6-8
93 + Cold Weather, 4-5
Either gas + Summer 3-4
Old 03-20-2023, 11:51 AM   #7
nickbettschen
Drives: 2020 Camaro 2SS Convertible
Mine takes 0 CRANKS.... cause i never shut it off!
nickbettschen is offline   Reply With Quote
Old 03-20-2023, 03:25 PM   #8
ironfang
Love all the info posted here. Thanks guys. Sorry in advance, I am sure I will have other worry-wart questions.
Old 03-21-2023, 04:59 PM   #9
ironfang
So it had a hard time turning over today after coming out of a store, had been driving for 15 mins prior. All the way home it wasn’t charging. I had seen it do this on another Camaro I rented in Vegas, coasting downhill would cause the charge to jump back to 14v and drop again as soon as I drove it.
Got home and it will not start tries to turn over and stops. Battery voltage is 11.9 with car off, before I shut car off voltage was 12.45
I have car on charger now, I’ll bet when it’s charged it goes back to normal and alternator starts charging at +14v again. What’s up with these electrical systems. I was luck to get an aftermarket warranty on it but it’s only been on for 2 days and I’m afraid they are going to claim pre-existing.
Old 03-21-2023, 05:11 PM   #10
jcharm
Drives: 2021 LT1 Camaro
Always just one button push for me. ;-)
Seriously though I'd say 2-6 cranks - ambient conditions seem to have no bearing. when cold starting.
I remember my Dad's 73 Catalina, which was always in prefect tune, would literally start on 1 crank every freaking time.
jcharm is offline   Reply With Quote
