Old 03-15-2023, 01:56 PM   #1
SSFury
My Road Rage is Legendary
SSFury's Avatar
Drives: 2011 IOM 2SS/RS "Fury"
Adjustable Engine Sound ??
How's it going everyone? Got my Shadow Grey Metallic Z 2 Days ago. The first thing that hit me, was the complete lack of noise. The car is quiet as hell. Ive driven an SS Camaro for 12 years, but I've stalled this one 3 times already because I CANT HEAR the engine. I have to stare at the RPM gauge to see where it's at.
I see the car has an "Adjustable Engine Noise". I adjusted my SS Noise with a Night Fury Cam, Kooks Long Tube Headers, and a Borla ATAK Exhaust.
How is the engine noise adjustable? Is it some sort of speaker system, or do things actually change? Just trying to figure this car out.
Every Time You Buckle Up In That Car, Tonight Might Be The Night That You Die.
SSFury is offline   Reply With Quote
Old 03-15-2023, 02:01 PM   #2
FarmerFran
FarmerFran's Avatar
1. Infotainment center goto vehicle and change engine to track
2. Put HUD in speedo/tach mode and raise it until it is right below where you look
<Insert Cars You Own Here>
Old 03-15-2023, 03:41 PM   #3
Vigilante375
Drives: 2018 Camaro ZL1
Is called the NPP exhaust and it can make the exhaust quiet or loud. If you put it in sport or track and are cruising at a steady speed, the exhaust valves will close but will open back up when you get back on the throttle.
You can adjust the suspension, exhaust and steering independently in the infotainment screen under settings then vehicle.
Under each setting you can put each component into its own independent mode or leave it to auto.
You can leave them to auto which means when you use the mode selector below the gear shifter, they'll go to that mode. Snow/ice, tour, sport or track.
If you turn the vehicle off while in track mode, it'll go back to tour the next time you turn it on. Snow/ice, tour and sport will stay selected when you turn the vehicle off.
Old 03-15-2023, 03:51 PM   #4
SSFury
SSFury's Avatar
Thanks for the inputs fellas. Yeah, im scrolling through the info system, and have been tinkering with the different settings. I guess I was just wondering more.. "Mechanically" how things could be changed. Different timing on the valves makes sense.. just something else to worry about breaking down the road. Its a ZL1. Make it sound like a beast from the factory and leave it alone!! Haha. I guess it being so completely quiet just caught me off guard. I didn't buy a Tesla after all...
Old 03-15-2023, 04:27 PM   #5
FarmerFran
FarmerFran's Avatar
Not sure what exactly you are looking for but when my dual mode is in Track it is pretty loud.
And the HUD adjusted correctly makes shifts super easy.
Old 03-15-2023, 04:52 PM   #6
Vigilante375
If you really want an exhaust tone then you need to get an axle back exhaust. Then it'll be loud all the time but you can get ones that accept the factory NPP valves so you can retain the quiet function.
The ZL1 isn't a problematic vehicle. Just keep up with the basic maintenance and it'll be good to go. There was a lady who bought a ZL1 brand new in 2017 and recently sold out with over 220k miles, a manual as well. She had 0 issues with the car and only did the servicing the car needed when it needed it.
Old 03-15-2023, 05:57 PM   #7
PMCamaro
Drives: 22 ZL1
Pull fuse 51 will open the exhaust as loud as stock can be
2022 ZL1 M6
PMCamaro is offline   Reply With Quote
Old 03-15-2023, 06:15 PM   #8
RamAir02
Shadow Gray '19 ZLE M6
RamAir02's Avatar
Drives: '19 ZL1 1LE M6
It sounds like you consider cam, headers, exhaust to be "adjustable engine noise"
Have you considered doing cam, headers, exhaust on your ZL1? And for more intake noise, add a CAI to that list.
YouTube
Old 03-15-2023, 07:57 PM   #9
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
I would start with a CAI and set your exhaust in Track mode as was said by Fran. It should be somewhat louder cruising around and definitely louder at full throttle.
Old 03-26-2023, 09:32 PM   #10
SHE'Z 18
SHE'Z 18's Avatar
Drives: 18 ZL1 - M6
Does the new ZL1 mean you and the Mrs. will be adding more “magazine worthy” pics to your album!?!? In any case, I hope you (both) enjoy that beautiful Z!
SHE'Z 18 is offline   Reply With Quote
