Old 03-14-2023, 09:16 PM   #1
truckrglenn
truckrglenn's Avatar
Drives: Chevy camaro
Lower Steering Wheel Plaque
I'm not exactly sure what it's called, but the Plaque on the lower part of my steering wheel was peeling. Looked kind of ugly so I purchased a new replacement.
Taking off the old one and installing the new one was easy and only took a couple of minutes. The part is not glued and using a plastic automotive trim removal. I slid it in between the plaque and the steering wheel far enough to be able to lift the plaque free. I did it that was so as not to damage the leather.
When installing the new one, slide it in on an angle under the air bag. When it's all the way up, lay it down and hit it in the center to seat it.
The top one on my leg is the older one. I did notice that the part numbers are different.
Glenn
SOLD - 2017 Camaro 2LT RS Convertible
2017 GMC Arcadia Denali
truckrglenn is offline   Reply With Quote
Old 03-15-2023, 07:53 AM   #2
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
Looks good! Mine did the same thing - the paint was peeling off. I took the part off and peeled/cleaned all the top coat of paint off. The peeling paint came off much like plasti-dip paint does. Once cleaned off it looked fine. It was just a little glossier but not that noticeable of a difference. I figured a new one would just start peeling again.
476 rwhp/440 rwtq (sold)
Old 03-15-2023, 06:09 PM   #3
truckrglenn
If I would have thought about it, I would have done the same. But would have picked up a rattle can and sprayed it.
Glenn
Old 02-27-2024, 05:02 PM   #4
17CamaroDenton
Drives: 2017 Camaro 2LT - RS Convertible
Replacing the steering wheel F Cover
Thanks for the information. I was wondering how hard it was to get the old cover off.
When I bought my 2017 in December, the cover you mention looked much like yours, but to make it worse, some of the paint flecks were transferred to the leather. I've got the new cover ordered, but still have to figure out how to remove the flecks of paint from the steering wheel.
17CamaroDenton is offline   Reply With Quote
Old 02-27-2024, 05:20 PM   #5
Use a plastic trim tool (such as the ones in this kit) and gently, but firmly pry it up from the bottom. Cover the tool in a thin microfiber or velvet cloth to avoid any scratches in case your hand slips.
