Old 03-14-2023, 04:15 PM   #1
Matos1LE
Drives: SS 1LE
1LE Brake Bleeder Swap
Hello everyone. I was searching on here and couldn't find concrete info. I want to install Stahlbus bleeder valves on my SS 1LE but I can't find the complete thread spec. I saw a thread that said they are M10x1.0, but how long does the thread need to be? Is it 16mm? If I get that figured out, I will update this thread with install pics and overall experience.
Matos1LE is offline   Reply With Quote
Old 03-15-2023, 01:20 PM   #2
Jason Mellon
Jason Mellon's Avatar
Drives: 2017 Chevy Camaro 1LE & 2023 1LE
I’m sorry, can you explain what this is? I’ve never heard of this. Anything that can help or make easier I would appreciate knowing more…JM
Jason Mellon is offline   Reply With Quote
Old 03-15-2023, 02:59 PM   #3
MatthewAMEL
MatthewAMEL's Avatar
He is asking about these...
https://www.stahlbus-us.com/bleeding...leeder-valves/
They also make oil drains.
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
2025 Hysteria Purple
C8 Z07
Old 03-16-2023, 08:39 AM   #4
Matos1LE
Drives: SS 1LE
They're basically a two piece brake bleeder. The first piece threads into the caliper so you don't have to unscrew the part in contact with the caliper, thus not wearing the aluminum threads in the caliper. The second part threads into that and it has a spring loaded ball that acts as a one way valve so air doesn't get in as you bleed.
Old 03-17-2023, 10:00 AM   #5
Jason Mellon
Speaking of oil drains, I just found this too;
https://www.valvomax.com/pages/produ...47&wizardId=22
Old 03-23-2023, 10:20 AM   #6
Matos1LE
Drives: SS 1LE
Form factor wise, it looks exactly the same as the Stahlbus. I am curious as to how it works though. There seems to be a different drain/hose part.
Old 03-23-2023, 05:10 PM   #7
snicko
Drives: 2021 SS 1LE
Uhh.. yeah.. interested in this as well. Please update with what you find
snicko is offline   Reply With Quote
Old 03-23-2023, 11:04 PM   #8
Garrettcat
Drives: 2017 camaro 1ss 1le
M10x1.25x29mm gm part# 13579453
Garrettcat is offline   Reply With Quote
Old 03-24-2023, 09:54 AM   #9
Matos1LE
Drives: SS 1LE
Thanks for the part number! Is this for a standard SS or does it apply to SS 1LE?
Old 03-25-2023, 04:33 PM   #10
78yellow78
Drives: 2017 Camaro SS 1LE
I would also like confirmation that 10x1.25x29mm is for the 1le. I looked at rock auto and I'm getting conflicting info. How critical is thread length?
78yellow78 is offline   Reply With Quote
Old 03-27-2023, 02:54 PM   #11
Matos1LE
Drives: SS 1LE
I would think it's very critical that the thread not be too short as the bleed screw needs to bottom out in order to seal. Having one that is too long could be a nuisance if it is excessive and the screw can now contact something and be damaged, but that would have to be really long.
Old 03-28-2023, 10:43 AM   #12
78yellow78
Stahlbus has a 10x1.25x20. That's as close as you get. I would love to do this. I have a lot of brake work coming up. If anyone knows more about 1le calipers or has installed these, please let us know. It would be a huge help.
Old 03-28-2023, 11:03 AM   #13
RamAir02
Shadow Gray '19 ZLE M6
RamAir02's Avatar
Drives: '19 ZL1 1LE M6
This is another one-person method for brake bleeding. It's my preferred option. Just something else to consider.
https://www.amazon.com/gp/product/B000TK9FE8/
YouTube
Old 03-28-2023, 01:53 PM   #14
Matos1LE
Drives: SS 1LE
I've got that setup as well. I'm thinking of modifying the cap so I can just hook it up to my air compressor. I have a machined cap that connects to a compressor for my Tacoma and it is cake to bleed that way; no need to keep pumping a reservoir. The nice thing about adding these Stahlbus bleeders is that you can use them in conjunction with the pressure bleeder for added confidence. I have this dream of just hooking up a bottle to each of the four calipers and bleeding them all in one go lol.
