Old 03-13-2023, 12:30 PM   #1
wang970305
Drives: 2021 Camaro 2SS
Tune out AFM?
I am kinda considering purchasing a tuner and tune out the AFM, but the car is still new and I know it would void the warranty. so I still debating on it. anyone has an idea how hard the tune is and is it worth it?
or I should just get an afm disabler and tie the afm valves on the gas tank?
wang970305 is offline   Reply With Quote
Old 03-13-2023, 04:18 PM   #2
How about a Range device? You can keep it plugged in and you'll need neither a tune nor any hardware mod.
Old 03-13-2023, 05:29 PM   #3
wang970305
that is what is in my mind, but I don't know if the actuator would cause a CEL with its making contact with the zip tie
Old 03-13-2023, 07:34 PM   #4
lt4camaro
lt4camaro's Avatar
Drives: 2021 LT1 10 speed auto
I believe the range device works with out touching the Actuators. I have mine tuned out, makes the whole driving experience so much nicer.
lt4camaro is offline   Reply With Quote
Old 03-13-2023, 08:28 PM   #5
Yeah, that's what I'm talking about. You don't need to do anything else, wang970305, just leave the AFM valve actuators alone, the Range dongle will disable them in software as long as it's plugged into the OBD-II port. An easy and trivially reversible "mod".
Old 03-13-2023, 08:40 PM   #6
wang970305
So I can unplug the actuators when obd2 is plugged in?
Old 03-13-2023, 09:36 PM   #7
FarmerFran
FarmerFran's Avatar
Yep, have to do it... Factory Tuned Out
<Insert Cars You Own Here>
Old 03-14-2023, 12:02 AM   #8
You couldn't resist, ha
Why do you insist on unplugging them? The actuators will default to their V8 state and never move as long as the Range device is in the OBD-II port. This is the whole point, you don't want to trigger a CEL or have to tune the AFM valve error code out etc., it's plug and play and removable without a trace.
Old 03-14-2023, 09:48 AM   #9
wang970305
sorry for not making it clear, Louisiana's annual inspection requires an OBD2 plugin... i don't wanna have a CEL when i unplug my Range device during the insepction
Old 03-14-2023, 11:14 AM   #10
haggler
haggler's Avatar
Drives: '23 2SS RSblue 6MT, sold '19 ND2
it wont throw a CEL when removed.
'23 2SS, 6 speed, NPP, Copper-free brakes, 56V Carbon Flash Rims, Riverside Blue
1LE sway bars
EOS front splitter
5-6-22:1100,
7-19-22: 3000,
8-3-22: TPW 8/15/22,
10-4-22: ETA 10/13/2022
10-15-22 6000
haggler is offline   Reply With Quote
Old 03-14-2023, 11:18 AM   #11
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
This^. If you make hardware changes (for example, a different catback with no AFM valves), you have to tune it out *BEFORE* you install the hardware. Or you WILL get permanent codes that you cannot get rid of! To this day, I still have AFM codes from throwing out the stock catback 4 years ago thinking I could just tune it out later…! Those codes show up as permanent codes during my annual inspection but with the SES light off, I still pass thankfully. But I learned my lesson.
See above. Hardware changes = tune needed. The Range is great if you just want something that stops the car from going into AFM mode without making hardware changes.
Old 03-14-2023, 11:22 AM   #12
Joshinator99
Moderator
It will if he unplugged the actual AFM actuators…
Old 03-14-2023, 01:54 PM   #13
wang970305
I have seen people ziptie the actuators on the gas tank and keep them plugged in and has no issue so the ECM still thinks those valves are in good condition. If the ziptie is blocking the actuators when it tries to move then you would get a CEL. I just hate Louisiana plug-in OBD during the inspection
Old 03-14-2023, 02:48 PM   #14
Joshinator99
Moderator
AFM is more than just 2 valves in the exhaust…. You realize that, right? I told you the right way to do it. If you want to screw around with some other way, Godspeed….
