![]() Drives: 18 ZLE, 18 SS1LE, 16 SS, 23 ZL1 Join Date: Jan 2021
I think my clutch is going out. Replacement?
Well it is just never ending with this car, if you’ve seen my thread on my Copart build. Had a leaking crankshaft seal and replaced it with the LS3 seal today. When torquing the Innovators West pulley back on to the recommended 130 ft. Lbs, with the car in gear and the parking brake on, the engine would turn before hitting 130 lbs. rear tires did not move. Although it drives normal with no noticeable slipping, it should not do this.
Does anyone have a recommendation on a replacement clutch? I plan on using the car on the street and road course track says. |
Long live the ICE...
Drives: 2020 Camaro ZL1 Join Date: Jul 2021
I would personally wait for more symptoms than the pulley install.
2020 ZL1 in Satin Steel Metallic.
![]() ![]() ![]() ![]() ![]() ![]() Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
I concur with Cosmok. 130 ftlbs at 0 rpm is not equivalent to 130ftlbs at 1000+ rpm. If you do replace the clutch though, go ahead and freshen up those heads and install a Katec or the latest gm oil pump. You're obviously not afraid of work and if you lose a motor to a dropped valve, you're looking at over 20k for a crate LT4. At your mileage, I can't imagine that there is anything wrong with your shortblock. Too many unknowns with that valvetrain though. The additional labor involved vs just doing the clutch is fairly minimal. Dropping the engine and trans out the bottom is less of a a PITA than wrestling the transmission out by itself. Once the motor is out, addressing the heads and pump is not a big deal. You can pull a rod or main cap or two while you're at it just to verify the integrity of the bottom end.
Baby Blue
#5 | |
E
![]() Drives: 14 Camaro SS 1LE Join Date: Feb 2019
The factory LT4 and LT5 clutches are great, I would just get a new OEM clutch. They are good for nearly 900rwhp without any issues.
#7 |
#8 |
Question ;OEM clutches on ZL1, are they single disc
Or dual disc ? |
#9 | |
Having FUN in the SUN...
![]() Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
ZL1 = Dual Disc...
2022 M6 ZLE: GMS Stage.III KONG X.PORT Package + DMS Lid + GMS Rear Bumper Belly Pan + GMS Hood Bracket + GMS Flex Fuel Package + MONSTER Triple S Clutch + XDI.50% Injectors + CLICK FOR BUILD LIST or www.GRIFFIN-MOTORSPORTS.com = 915rwhp 850rwtq + E60 + 15psi
#10 | |
You really should use a flywheel lockout tool when removing and installing a balancer. Thats A GM SOP
#11 |
![]() Drives: 2019 ZL1 1LE Join Date: Feb 2017
I'm pretty sure the OEM clutch uses centrifugal forces when spinning to provide more clamping power. I'd be real surprised if it was bad unless it has some sort of failure in the pressure plate (or disc?).
Old: 2017 SS 1LE
Old: 2017 ZL1 Current: 2019 ZL1 1LE |
#12 | |
![]() Drives: None Join Date: Jan 2018
#13 |
#14 | |
376 cubic inches of fun
