![]() Drives: Camaro ZL1, Golf R Join Date: Feb 2022
“Timing” Suspension Bushings
Good morning all,
I’m looking to install BMR lowering springs and the BMR cradle lockout on my car. I was going to attempt the install myself in the garage but I came across a thread highlighting the importance of “timing” the bushings when doing the spring swap. I had never come across this before, but it makes sense. For those that don’t know you’re supposed to leave all the suspension bolts loose while you lower the car to ride height and then tighten everything down so that the bushings are “neutral” and not in a bind at ride height. My question is have any of you with lowering springs done that? I can’t imagine it makes a huge difference as the BMR springs only lower the car about 0.4”. For me, having to do this is the difference between taking it to a shop and doing it myself. I don’t really want to have it teetering on jackstands while trying to figure it out. Thanks!
’22 ZL1 Riverside Blue 6MT
’17 Golf R Limestone Grey DSG |
#2 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
#3 | |
![]() Drives: 2024 ZL1 M6 Join Date: Sep 2018
2024 Riverside Blue ZL1 M6
Magnuson 2650R, NW 103, Roto Fab Big Gulp Kooks 2 inch LT's, Stainless Works Legend NPP THP Billet Valve Covers, Mighty Mouse Wild CC Signature Forged 20x10.5/20x11.5, BMR springs, BMR Cradle lockout, AAD Billet arms 2023 Vivid Orange ZL1 M6 - sold 2019 Riverside Blue ZL1 A10 - sold |
#4 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
Coming from the Gen5 community and now as a Gen6 SS 1LE owner, I see less conversations about timing the bushings among the Gen6 groups. I'm willing to bet most guys doing springs haven't done it. GM calls out timing the bushings in the service manual as tightening the suspension joints at ride height. So this is something that is important. Yeah, it adds time and cost to just doing drop springs but do it once, do it right.
"KEEP THE FAITH"-Fbodfather Last edited by cdb95z28; 09-19-2024 at 07:16 AM. |
TO add a wrinkle the OP says Jack stands and you can't time bushings on jackstands you'd need wheel cribs or a lift. Just another reason I'm probably going to waive off of lowering springs. And then this TTY bolts. Its great to really know what you're getting in to!
https://www.camaro5.com/forums/showthread.php?t=153188
https://www.google.com/search?q=timi...1&dpr=0.8#ip=1
"KEEP THE FAITH"-Fbodfather |
#7 |
![]() Drives: 2022 ZL1 M6 Join Date: Mar 2022
What I've done in the past on my last car is once my car is jacked up on stands I used my floor jack to load the suspension and then loosen and re-torque to spec. I do one side a time. Then I get it re-aligned.
2022 Black ZL1 M6
RF intake, Soler TB & TC, ADM v2 reservoir, AWE Touring non-resonated catback exhaust. 535 whp, 537 tq. SAE Smoothing: 5. DynoJet. No tune. 91 octane. |
#8 |
Thanks for the info guys. Does anyone have the pages from the service manual needed for a spring change? I haven’t bought the service manual yet. I’m thinking about picking up the ACDelco subscription for long enough to download the info I need. Hopefully that will highlight which bushings need to be timed and which TTY bolts I need to purchase.
Has anyone done this on jackstands? Does the car need to be perfectly level?
#9 |
To get perfect static ride height, the car should be as close to level as possible.
I have the service manual info. I'll share it sometime today. When I did my AC Delco TDS I downloaded over 1200 pages just on the Gen6 alone. I did all my other GM vehicles at the same time. Best $20 I ever spent.
#10 |
From what I've found, the only rubber suspension bushings are:
At the rear: -Every joint on the knuckle except the lower control arms and toe rods -Upper and lower trailing arms at the subframe -Lower control arm at subframe -Anti roll bar mounting at the subframe. These bushings are actually glued to the bar and there is no way to loosen the bushings from the bar to time them to a new ride height. At the front: -Radius rod at the subframe. This is the forward diagonal arm. -Anti roll bar mounting at the subframe. Same explanation above as the rear anti roll bar If not mentioned above, then they are rose joint type joints which have no inherent bind. These are similar to spherical joints and they can rotate and re-center to a new static ride height. The fastener torque spec files show which fasteners are to be replaced. FRONT MAGRIDE STRUT.pdf MAGRIDE SPRING.pdf MAGRIDE STATIC HEIGHT RECAL.pdf REAR SPRING.pdf SUSPENSION FRONT FASTENER TORQUE SPECS.pdf SUSPENSION REAR FASTENER TORQUE SPECS.pdf FRONT CAMBER ADJUSTMENT.pdf ABS FASTENER TORQUE SPECS.pdf BRAKE SYSTEM ADHESIVES AND LUBRICANTS.pdf BRAKE SYSTEM FASTENER TORQUE SPECS.pdf
#11 |
Man thank you that is excellent information. I really appreciate you posting all that.
