Old 03-07-2023, 07:52 PM   #1
db2022cs
Drives: 2023 2SS 1LE
Numbers on bottom of 1le e-diff
I was under the car today doing the diff fluid change. I waited a bit longer to do this than I would have liked but fluid looked fine, there was a decent amount of sludge and debris on the magnetic drain bolt. But it's taken care of. While I was under the car, there were numbers written on the diff and I was curious what it is?
Also, I need to order some new ramps, I'm sure it's fine but my last cars didn't have wheels as wide as these.
2023 Riverside Blue Metallic 2SS 1LE Camaro
2021 Black Hyundai Veloster N -Sold-
2016 Grey Chevy Volt -Sold-
2018 Blue AWD Kia Stinger GT2 -Sold-
db2022cs is offline   Reply With Quote
Old 03-08-2023, 07:41 AM   #2
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
Those are lash measurements from when the diff was built.
You don't need wider ramps.
Old 03-08-2023, 10:37 AM   #3
db2022cs
Thanks, I was sort of thinking it was factory measurements but wasn't sure for what. I'll probably get new ramps anyways because these don't work for the front as the 1LE lip hits the ramp and I'm super paranoid in using the jank methods with boards or whatever to get the clearance.
Old 03-08-2023, 12:27 PM   #4
Ryfly05
Drives: 22 2SS 1LE
Out of curiosity, is your car manual or automatic? My manual trans 1le diff tolerances are way tighter.
Ryfly05 is offline   Reply With Quote
Old 03-08-2023, 12:38 PM   #5
db2022cs
It's manual.
