Old 03-07-2023, 12:56 PM   #1
TeamOne
Drives: 2022 Corvette
Brand New Camaro Transmission Issue
We special ordered a brand new 2023 Camaro SS with the manual transmission. Customer signs papers, drives off, and has major problems within a mile of leaving dealership. When stepping on the gas hard going past 4000 rpm to vehicle just throws the shifter out of gear and a message about the clutch and decreased engine power briefly flashes on the dash. We can duplicate it every time. Any thoughts on why this is happening. Obviously the customer is not happy
TeamOne is offline   Reply With Quote
Old 03-07-2023, 01:00 PM   #2
ctrlz
Loose reluctor for vehicle speed sensor:
https://www.camaro6.com/forums/showp...7&postcount=10
I don't exactly know why it would pop out of gear by itself.
Old 03-07-2023, 01:40 PM   #3
GXP08jrf
Drives: 2016 1LT 'Vert
break in
https://www.chevrolet.com/content/da...ackPREP-R3.pdf
Exceeding 4000 RPM should be avoided within the 1st 500 miles on a new SS per the Camaro break-in guidelines.
GXP08jrf is offline   Reply With Quote
Old 03-07-2023, 01:42 PM   #4
ShockingZ
Drives: Chevy Camaro ZL1
Still that would not cause this issue.
ShockingZ is offline   Reply With Quote
Old 03-07-2023, 01:55 PM   #5
ctrlz
Bad synchros?
https://www.camaro6.com/forums/showthread.php?t=477475
Old 03-07-2023, 02:04 PM   #6
Gen6cyl
Drives: Chevy Camaro 2021 ,rs, v6, manual
Excellent way to keep you from going over 4k rpm.
Gen6cyl is offline   Reply With Quote
Old 03-07-2023, 02:13 PM   #7
FarmerFran
FarmerFran's Avatar
LMFAO!
Sorry there are having this problem. But no clue.
<Insert Cars You Own Here>
Old 03-07-2023, 03:58 PM   #8
rst08tierney
Drives: '23 2SS Rapid Blue
when a dealer reaches out to the community message board for help
rst08tierney is offline   Reply With Quote
Old 03-07-2023, 04:11 PM   #9
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
Yep, I take it as an acknowledgement for the quality of our (not mine- I ain't got a clue!) quality of information and shows this is a dealer that will listen and readily accepts the input- which is a pretty rare thing.
Ventmaster is offline   Reply With Quote
Old 03-07-2023, 04:37 PM   #10
Casper the friendly G
Drives: 17' Chevy Kamaro SS 6 speed
Probably something out of adjustment. Never heard anything going wrong with manuals.
Casper the friendly G is offline   Reply With Quote
Old 03-07-2023, 05:43 PM   #11
LT1gen6
LT1gen6's Avatar
Drives: '22 LT1 Coupe
Originally Posted by TeamOne View Post
We special ordered a brand new 2023 Camaro SS with the manual transmission. . vehicle throws the shifter out of gear and a message about the clutch and decreased engine power briefly flashes on the dash.
Anecdotes are entertaining, while paling in comparison to to a dealer's access to Chevy technical support services. Contact them.
LT1gen6 is offline   Reply With Quote
Old 03-07-2023, 06:24 PM   #12
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Take it back to the dealership and let them figure it out. It’s a new Camaro and that’s what the warranty is for.
Old 03-07-2023, 06:30 PM   #13
LeonardS
I think he is from the dealership.
94 Z28, Black, M6, 595 miles
69 Z28, Dusk Blue, M4
29 Ford Business Coupe
28 Ford Pickup
24 GMC Denali 2500HD CCSB 4x4
22 Jeep Grand Cherokee
13 Ford F150 Crew Cab 4x4
Old 03-07-2023, 06:32 PM   #14
Msquared
Msquared's Avatar
Drives: Chevrolet SS 1LE
There's no mechanism inside a T6060 that would enable it to actively take the transmission out of gear, nor should there be. That's dangerous. Same goes for the clutch: there is no way for the car to actively move the clutch without the driver's input.
Something is wrong with that transmission internally. It's not a synchro, as that would come into play when shifting into a gear but has nothing to do with it staying in gear. It almost sounds like one of the gears has the teeth cut wrong. Most likely, they just need to replace the transmission.
Matt Miller
2020 SS 1LE
Msquared is offline   Reply With Quote
problems, transmission problem, warranty
