Old 03-06-2023, 01:40 PM   #1
stormtrooperSS1le
Drives: 2017 camaro ss 1le
Code p2119 throttle body serviceable?
Hello I have a NW 103mm TB and I have this code relating to throttle sctuator control. Has anyone successfully moved tps and tac over from an old throttle body to a new one? The dealer says I need a new throttle body. I find it hard to believe the little black box on the side of the TB can’t be replaced?
stormtrooperSS1le is offline   Reply With Quote
Old 03-06-2023, 04:47 PM   #2
stormtrooperSS1le
No one has ever had an issue with their throttle body before?
Old 03-07-2023, 08:14 AM   #3
stormtrooperSS1le
Any ideas or can you only get a new throttle body?
Old 03-07-2023, 08:19 AM   #4
ctrlz
Can you see a part # on the actuator assembly? Once you ID it, I would go to ebay and buy a used TB with that actuator. Slight risk going with a used part, but I can't find actuators sold separately.
ctrlz is online now   Reply With Quote
Old 03-07-2023, 04:52 PM   #5
stormtrooperSS1le
Yes sir photo is attached I have been looking and also can’t find just the sensor.
Old 03-08-2023, 10:46 AM   #6
ctrlz
It appears they are stamping the part number for the whole TB assembly on the plastic actuator.
https://www.gmpartsdirect.com/oem-pa...2713774?c=az0x
Looking at this, it appears you should be able to buy another one and just swap it. Since the position sensor and actuator motor are inside the same housing, there is nothing that can get out of calibration. This idea seems to be supported by what I read online, and probably reflects why they build and sell them this way.
I would still do my best to make sure the old TB and new TB are both at the idle position before proceeding with the swap.
You are looking at about $50 for used and $80 for a new TB on ebay. realistically, if you could buy a new actuator separately, it would probably be about $50-60.
Old 11-30-2023, 01:42 PM   #7
BigHungry
Drives: Chevy Camaro
Any update on this? I’m having the same issue and wondering if I need to just order a new throttle body
2022 Camaro Lt1 a10 - Rotofab dry, Katech 103, Msd atomic, Longtubes, Corsa Npp axleback, e85 tuned. VMS dragpack
BigHungry is offline   Reply With Quote
Old 12-26-2023, 09:50 AM   #8
ctrlz
Relatively low risk to try it, plus many vendors will accept returns.
Just make sure you get a TB for the V8. All those actuator/sensor assemblies look the same. There are differences for the 4 and 6-cyl versions though.
