Old 03-05-2023, 12:18 AM   #1
dbs1
Drives: 2017 ZL1
What tires actually dead hook for 1/4 mile?
I’ve got triple r’s for the street and 1/2 mile and some supercar tires for the road course, but thought I’d try the qtr mile after not running a car down one for 15 years and the triple r’s sure don’t work the same as the MT full drag slicks on the 67bbc of you’re with 1.39 short times.
So what does actually hook on these cars?
dbs1 is offline   Reply With Quote
Old 03-05-2023, 07:31 AM   #2
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
are you running 555 or 555RII
Old 03-05-2023, 08:27 AM   #3
Z OH 6
Drives: 2024 CT5-V Blackwing
MT ET Street R
Old 03-05-2023, 08:30 AM   #4
JSH
JSH's Avatar
Drives: '20 ZLE
No subject has been discussed here more than this one. If you're looking for a rear tire only for the strip, then the most popular tires are MT ET Street (bead lock), Nitto 555Rii drag radial, and Toyo R888R. I'm currently using Toyos, which are a track tire, because they are good on every surface except wet/cold. I'll buy the NT 555 RII, P345/30R19 if and when it becomes available again. I might change to a 20" wheel.
The Mickey Thompson ET Street R is a Bias Ply Drag Tire, while Mickey Thompson's D.O.T.-approved ET Street S/S (Street/Strip) Radial Tire can be driven on street or strip. I tried the "R" tire in 2021 and 2022 and did not like the soft sidewall feel on the street or strip. I have not tried the S/S.
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 03-05-2023, 09:51 AM   #5
Jaydoubleyou
Drives: Camaro
I’m fixing to buy my first set of tires. I have P4S AS ZP’s that came with the car. Looking at 285 or 295 up front. And 315 or 325 on rear of stock rims on ZL1 20” I guess. I’m thinking of going with P4S for front and maybe 888 or 555 on rear. Not sure what to do.
19 ZL1 Mosaic Black, M6 like a dude with all the fixins.
10 SS Aqua Blue (Sold)
93 RX7 475rwhp (Sold) regrets there
Jaydoubleyou is offline   Reply With Quote
Old 03-05-2023, 11:32 AM   #6
JSH
JSH's Avatar
Drives: '20 ZLE
I do not believe the 555RII is available right now
2020 ZL1LE A10.
Old 03-05-2023, 12:05 PM   #7
Jaydoubleyou
Drives: Camaro
I do not believe the 555R2 is available right now
The G2 is available on tire rack wondering how they would be. I had some 555 on my RX7 and they were great.
Old 03-05-2023, 02:00 PM   #8
The G2 is a regular everyday tire, aka little league compared to the RII. Don't even give it a thought if you want superior rear traction with your ZL1.
Old 03-05-2023, 02:22 PM   #9
SteveV
SteveV's Avatar
Drives: 2018 ZL1 Camaro 6M Red Hot
You are partially correct. I have been unable to find the NT555RII in 305/30R20... However, the 305/35R20 is available from several sites including Amazon.
I am running this size on my 2018 ZL1. But if you are holding out for the 305/30R20, discount tire has them on back order.
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
SteveV is offline   Reply With Quote
Old 03-05-2023, 02:26 PM   #10
Jaydoubleyou
Drives: Camaro
I’m not super familiar with the difference on them if anyone knows please share. I looked and really came up empty they look the same to me. Maybe it’s a compound thing?…
Old 03-05-2023, 03:13 PM   #11
grampa_ss
grampa_ss's Avatar
Yes….it’s a totally different compound. I’ve had both the Nitto 555 G2 and the 555 RII. They are not even in the same ballpark. The G2 is a horrible rear tire. And as most of us agree, the RII is a good all around tire and a true drag radial & what most of us higher HP guys run on the street. I do run the G2 on the front as it matches the tread of the 555RII.
Old 03-05-2023, 09:10 PM   #12
Jaydoubleyou
Drives: Camaro
Found some 315/35/20 in the R2. Will they go on the stock ZL1? I know they had 30s on there before. Sorry for a being a newb. Thanks in advance y’all.
Old 03-06-2023, 04:12 AM   #13
Z OH 6
A lot of recommendations here for a street tire when OP said he wants a 1/4 mile tire. There are none better than the MT Street R.
Old 03-07-2023, 02:11 PM   #14
KILLA BEE
Black lightning
KILLA BEE's Avatar
Drives: 2021 ZL1 1LE A10
I also have the Toyo’s in 345,s love them. Curious when it’s 50-60 degrees out, IF you even drive your car then, what psi do you use. I’m guessing your tuned so I l know at wot your not hooking at the summer psi around 27 28 psi I was thinking around 22 23 psi in those temps??
[ 2021 Camaro ZLE 10 speed
KILLA BEE is offline   Reply With Quote
