Go Back   CAMARO6 > Members Area > Ask the Camaro Team
Old 03-03-2023, 11:26 PM   #1
2019_SS
Drives: 2019 2SS Camaro LT1
Unhappy Right Side DRL not working (Left side works)
I have a 2019 SS Camaro and my DRL (Daytime Running Lights) on my right side do not work, even the park indicator lights on the right side only, once every 15ish seconds they will flash and thats all. I am originally thought it was just the Brake light but its the whole right side including the front right headlight. Need help
2019_SS is offline   Reply With Quote
Old 03-04-2023, 12:21 AM   #2
Just an idea: DRLs and rear park/positon lamps are protected by BCM fuses F18 and F28 in the underhood fuse box, I'd check those first for proper seating and partial continuity issues.
Old 03-04-2023, 11:33 AM   #3
2019_SS
Not Fuses
I pulled them both out and checked and they are both good, I just found out that its also my DRL right side headlight as well, so the whole entire right side doesn't work but flashes every 15ish seconds
Old 03-08-2023, 06:26 PM   #4
h422694
h422694's Avatar
Drives: '16 Z06 7 Spd, 2024 High Country HD
Just curious if you checked to see if the problem threw any codes?
h422694 is offline   Reply With Quote
Old 11-18-2024, 08:38 PM   #5
2020 MonSSter
Drives: 2020 Camaro 2SS
I know this thread is nearly 2 years old, but did you ever find out what the problem was and fix it? I'm having somewhat of the same issue, except my front headlight is fine and the rear blinker and brake lights work, but the drl's wont come on on the passenger side. Fuses are fine and no codes are being thrown.
2020 MonSSter is offline   Reply With Quote
Old 11-20-2024, 02:09 AM   #6
Jtredcamaro23
Drives: 23 Chevy Camaro
So I’m sure I’ll not explain this right but let me try. When I turn my blinker on to turn right (up) NOTHING HAPPENS but the left side blinkers continue to blink even in the neutral position. Does that make sense? It’s not a hyper flash just a regular flash that will not quit. Bulbs are all good.
23 Camaro rs
Jtredcamaro23 is offline   Reply With Quote
Old 11-20-2024, 07:09 PM   #7
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Sounds kind of like you might have a problem in the turn signal switch in the stalk/lever. If it still blinks in the neutral position.
1JEWLDSSRS is offline   Reply With Quote
Old 11-12-2025, 12:03 AM   #8
Redrado
Drives: 2020 Camaro SS
DRL Failure
When my right DRL failed on my 2020 SS the dealership said it needed to be replaced. They wanted over $2k to repair it which requires bumper removal. I’ve noticed in forums it’s more common for the right side to fail. I’ve found replacement OEM’s around $240. I’ll probably replace both sides for equal wear due to labor cost. Estimates online say labor shouldn’t be in the $800 to $1200 range.
Redrado is offline   Reply With Quote
2019 camaro, drl, help me i'm a noob, not working
