Old 03-02-2023, 09:57 PM   #1
mitchellsack
Drives: 2022 Camaro SS 1LE
1LE Street alignment
Getting alignment done tomorrow after putting Eibach lowering springs. Is there any info out there about the stock alignment? Not track. I couldn’t find anything in the manuals.
Thanks in advance.
mitchellsack is offline   Reply With Quote
Old 03-03-2023, 12:36 AM   #2
N Camarolina
N Camarolina's Avatar
Drives: 2021 2SS 1LE
The alignment info is in the high performance supplement manual which accompanied your regular owners manual. The road alignment settings are shown in a table right alongside the track alignment settings.
N Camarolina is offline   Reply With Quote
Old 03-03-2023, 01:14 AM   #3
VR Baron
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE
My alignment was -1.3 front and rear from the factory for reference. Not sure that was correct
VR Baron is offline   Reply With Quote
Old 03-03-2023, 07:44 AM   #4
WhiteMale
Drives: 23 ZL1 A10 Rapid Blue
remember that it's TOE that wrecks tires and not neg camber.
Old 03-03-2023, 01:33 PM   #5
VR Baron
Correct. I run -2.5 to -2.8 front for years on Camaros no issue on street. Thought it’s not a daily. Wear is even.
Old 03-03-2023, 02:17 PM   #6
mitchellsack
Got it. Thanks
Old 10-03-2023, 10:04 PM   #7
pontiaco1
Drives: 2018 1LE
what camber you run on the rear and what toe?
pontiaco1 is offline   Reply With Quote
Old 10-04-2023, 10:20 AM   #8
VR Baron
-1.8, toe .125 total toe in to help traction off corners. This and front max I could get and for autocross. If I was on the street only I probably would just stick with the track settings per the manual
Old 10-05-2023, 09:19 AM   #9
pontiaco1
Drives: 2018 1LE
Do you see any wear on Your tires with this settings??
What tires you running?
I also do a lot autocross.
Thanks
Old 10-05-2023, 10:29 AM   #10
VR Baron
Thanks
Stk Sc3’s for street. 10000 miles on them. It’s not a daily. That said my fifth gen with -2.5 camber with Michelins was a daily had even wear of city/ freeway.
My autocross tires were the old re71r’s. This last set are Nankang crs.
A big wear factor is front toe. Keep it at 0 or only 1/16” in or out.
Old 10-05-2023, 11:17 AM   #11
pontiaco1
Drives: 2018 1LE
thanks!
