Old 02-26-2023, 02:41 PM   #1
#8ZL1Man
#8ZL1Man's Avatar
Drives: 2023 ZL1
Stock ZL1: Will 20x10 ET 20 or ET 23 SQUARE Set Work?
Hoping for help. Searched lots of posts but too many are confusing because they quickly get hi-jacked with Non-Square comments.
I want to run DD All-Season tires, with a bolt-on square set for my ZL1. Could care less about track considerations or rear hook-up. I think I could get OEM wheels in ET20 or MRRs in ET23.
I just want to look good in my convertible cruising, for 3 seasons, and get 40K+ out of a set of 285 tires.
Has anyone run either of these?
2023 ZL1 A10 Convertible (copper-free brakes)
________________________________
1973 Triumph GT6
2018 Mustang GT Convertible
2009 Viper Roadster
1970 Olds Cutlass Supreme Convertible
1967 Chevelle SS396 Convertible
2013 Corvette 427 Convertible
1965 Mustang Fastback (Shelby GT350 clone)
1969 Camaro RS/SS 350 Convertible
1967 Mustang Fastback 289 'HiPo'
2005 Viper SRT-10 Roadster
2003 Corvette Coupe
2001 BMW E46 M3 Coupe
#8ZL1Man is offline   Reply With Quote
Old 02-26-2023, 03:09 PM   #2
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
I believe the fronts will also work on the rear. You'll stick out about 3/8" further toward the fender, and gain a ton of clearance on the inside (1-3/8"), but I think it should work. I'm sure someone has tried it and can confirm, though. It should work strictly by the offset calcs though. Meaning, 20x10 et20 on all corners.
Mods being installed-
Old 02-27-2023, 05:35 PM   #3
crosive
Drives: 18 zl1
https://www.wheel-size.com/calc/
you can put in whatever you are planning into the calculator and it will give you a pretty good estimate of what you'll end up with (relative to what you entered for your stock fitment). i.e 3/8" closer to suspension components, or 3/4" more poke from fender.
it's helped me a lot on various vehicles.
crosive is offline   Reply With Quote
Old 02-27-2023, 08:01 PM   #4
#8ZL1Man
#8ZL1Man's Avatar
Drives: 2023 ZL1
This prior post helped:
Originally Posted by mariojas View Post
Update on my setup - 19x10 ET22 SM-10 rims are perfect for a front of ZL1 - sits flush with the fender like stock. But rears stick out a little, somewhere 3/8 - 1/2in, so I am not fully happy. ET35 probably would be better. Edit: after spending with them a day - I like it might look better than stock...
1973 Triumph GT6
2009 Viper Roadster
2003 Corvette Coupe
Old 03-03-2023, 09:01 PM   #5
#8ZL1Man
#8ZL1Man's Avatar
Drives: 2023 ZL1
Anybody know if 295/30/20 fits on 20x10 square set up (ET23)?
1973 Triumph GT6
2009 Viper Roadster
2003 Corvette Coupe
Old 03-04-2023, 06:27 AM   #6
Vigilante375
Drives: 2018 Camaro ZL1
I know you said it's not for a track setup but read this. There are square setup for different sized rims on different sized tires.
https://support.apexraceparts.com/hc...-Fitment-Guide
Old 03-04-2023, 08:05 PM   #7
#8ZL1Man
#8ZL1Man's Avatar
Drives: 2023 ZL1
Thanks. I've seen that. They're pushing 19" rims for lighter weight and performance on the track, and 11" wide rims for wide tires.
My 2023 ZL1 Convertible is a 'forever' car. My goal is 20" diameter (lots of options), and 10" wide rims (285 or 295 tires for better MPG and many A/S options).
I've had two Vipers, and I got rid of the last one, in part, because collectors will have a hard time finding 345/19 rear tires in a few years (as tire mfgs. focus more on electric cars, and those don't feature wide rubber due to their priority for lower rolling resistance). ...So I believe we're all going to be facing more limited rubber options for collector performance cars in the future.
1973 Triumph GT6
2009 Viper Roadster
2003 Corvette Coupe
Old 03-25-2023, 09:01 PM   #8
#8ZL1Man
#8ZL1Man's Avatar
Drives: 2023 ZL1
...Well now we know for sure that the party ends in 10 months.
1973 Triumph GT6
2009 Viper Roadster
2003 Corvette Coupe
