Old 02-22-2023, 01:44 AM   #1
Bx Tpr
Drives: 22 ZLE 6MT
Question Ported blower/snout TB gasket?
Are there any vendors that port the stock blower/snout that retain the OEM throttle body o-ring gasket? Or does one have to seal the TB to the ported snout with a gasket maker when any porting is done?
Thank you
Bx Tpr is offline   Reply With Quote
Old 02-22-2023, 05:19 AM   #2
Z OH 6
Drives: 2024 CT5-V Blackwing
My Kong ported blower and NW 103mm had to be sealed with silicone gasket maker.
Old 02-22-2023, 07:20 AM   #3
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1 - Beast Build
I was told the same thing by Greg at Kong, that I would just use 3M gasket maker after my SC was ported for a 103mm TB. I ended up going with a 100mm TB vs a 103mm TB. But, my installed also required an adapter that had it's own gasket. So my install was like: Supercharger flange, then supplied gasket, then TB adapter, then stock gasket, and then the 100mm TB.
