Old 02-21-2023, 05:28 PM   #1
carlythecamaro
carlythecamaro's Avatar
Drives: 2017 Camaro SS
Texas Speed 1 7/8 Headers rubbing on something when I make a wide turn
Does anyone else have this similar issue that runs texas speed? Or how to fix/ prevent this from happening?
carlythecamaro is offline   Reply With Quote
Old 02-21-2023, 05:35 PM   #2
Spaceme1117
Spaceme1117's Avatar
Drives: 2017 Camaro SS, 2011 Corvette GS
You can try to adjust them but likely there is nothing you can do.
I had a set of Texas Speed headers on my 02 Corvette Z06. Were well made, nice welds, etc. But they would rub on the tunnel of the car on left hand turns.
It's just not well engineering parts. Some people have not problems but many others do.
The solution is to remove them and get some Kooks.
Spaceme1117 is offline   Reply With Quote
Old 02-21-2023, 05:47 PM   #3
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Likely hitting the steering shaft. There are a couple options:
1) Use a button head bolt for the steering shaft.
2) If still rubbing, Heat the primary up that is touching and dent it.
3) Loosen motor mounts and use a pry bar to push the engine towards passenger side.
Old 02-21-2023, 05:49 PM   #4
carlythecamaro
ive debating on switching to kooks theres just a significant price change between the two
headers
