![]() Drives: 2016 Chevy Camaro 2SS Join Date: Sep 2020
How much power
I have FBO e85 2016 camaro ss manual. I was wondering how much power I will make if I go with a procharger and upgrade my pistons and rods and upgrade to lt4 fuel system.
![]() Drives: 22 LT1 Join Date: Apr 2022
Add a cam with a bigger fuel lobe also. You’re gonna need all the fuel you can get. You can make 8-900hp depending on the fuel you use
So if I do the rods and pistons and the fueling upgrades what would I make before I do any heads and cams.
I’ll be running e85 or 93 or both.
Probably around 650-700whp with fbo and the base pulley. 6-8psi and e50ish. Dont need to do rods n pistons yet.
That is kind of a loaded question.
First off, what model Procharger? What compression? With a stock cam the LT4 fuel system doesn't go that far. With a 38% fuel lobe and a P1x you can make 750-800whp on E50 @ 11-12psi. Going to need an aux low side or bigger tank pump as well. If you are doing rods/pistons you might as well delete DOD and at least run a cam with a bigger fuel lobe. BTR has a stock profile 32% fuel lobe if you don't want a larger cam. If it was my build I would do a D1SC @ 10psi, ToohighPSI port injection kit, and you can make around 700whp on full E85 without needing to open up the motor. This is coming from somebody who has spent money upgrading DI fueling, but the costs have since sky rocketed on the LPE HPFP to go this route. So currently PI is the more cost effective option.
#7 |
At some point I will port my heads and also add gpi ss3 cam in. Also do a full valve train upgrade. Should I use gpis standard or low compression piston and rods? I plan on doing the lt4 injectors, low side and high side. Then may add a smg aux pump in if needed.
#8 | |
![]() Drives: 2016 Camaro SS Join Date: Oct 2021
what King said is about the best setup to go with now. A solid reliable 700whp car is a very fun thing.
2016 Camaro 2SS 759whp 686wtq tuned by KingLt1
Procharger D1SC - Forged internals BTR stage 3 cam - Circle Stage 3 trans American Racing headers - Borla S-type |
#9 |
Do I stick with the standard or low compression piston and rods front gpi?
#10 |
Depends on what fuel you primarily want to run. If pump gas then do lower compression. If Ethanol leave compression stock...
#11 |
![]() Drives: 1SS Summit White 6 speed Join Date: Jul 2017
Boost+Pistons is no small expense
All said and done you might look back and regret not getting ZL1 at this point in the process. I've learned that modifying a car isn't like a video game. Complications always arise and even if you plan every step it's still building an LT1
16 1SS M6 White
Magnuson 2.3 Heartbeat Roto Fab Solo Performance Cat deletes and Axleback Hurst short shifter #'s coming soon Riaction coilovers 1LE sway bars BMR mm BMR chassis brace Flow one 19" wheels wrapped in Mickey Thompsons 02 Z28 M6 35th anniversary 80k miles T-tops Leather Bolt ons Joy to drive this classic every day! Daily Driver |
