02-18-2023, 05:56 PM | #1 |
Drives: blue velvet Join Date: Jul 2018
Blackwing brake ducts and ABS Speed sensor wire
Hi, I just received the CT5 Blackwing brake ducts and was about to install them today when I noticed that the sharp back edge closest to the rotor was rubbing against what I believe is the ABS Speed sensor wire. I didn't see an easy way to relocate it so that it didn't rub, but maybe this is a non-issue and I'm overthinking it. Didn't see this mentioned anywhere so I thought I'd check with y'all and see if anyone ran into the same concern.
Thanks! |
02-19-2023, 06:35 AM | #2 |
I drilled 2 small holes and secured it with a small tie wrap
02-19-2023, 09:55 AM | #3 |
America FVCK Yeah!
Drives: 2021 ZL1 1LE A10 Join Date: Mar 2013
I didn’t notice any interference on my ZLE? Is this just an SS issue or do I need to get back in there?
1997 Z28 Anniversary Edition SOLD
2004 GTO ORDER CANCELLED 2004 CTS-V SOLD 2005 CTS-V SOLD 2006 300C SRT-8 SOLD 2006 300C SRT-8 SOLD 2010 CTS-V SOLD 2012 CTS-V coupe SOLD 2013 ZL1 vert SOLD 2016 Callaway Z06 SOLD 2019 Z06 SOLD "I lived my life by one motto.......mottos are for losers" cvp33 |
02-19-2023, 10:18 AM | #4 |
Drives: 2020 SS 1LE Join Date: Aug 2020
OP, where did you source yours? I placed an order with my Chevy dealer but they said they’re on back order with no eta.
Thanks in advance! |
02-19-2023, 05:35 PM | #5 | |
Ended up using a small wire loom and a ziptie.
I went with ChevroletPartsDirect.com, part numbers, thanks to many of the other members of this forum who paved the way. 85536981 F Deflector $23.86 85536980 F Deflector $23.86 |
02-19-2023, 06:27 PM | #6 |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
I would not fasten that ABS wire to the deflector. When you turn the steering it will be stressed. I did not fasten mine. You car is not an SS 1LE is it? I'm not seeing any MagRide wire. My SS 1LE is protected by a heat shield and that shielding will help protect it from the deflector edge. You did good with the wire loom, but I would run loom from where the wire connects to the strut the entire way down to the knuckle.
02-19-2023, 06:35 PM | #7 |
Something I also did was I smoothed off the sharp edge of the deflector where the ABS wire would touch, just to help it rub against it smoothly.
02-19-2023, 10:43 PM | #8 |
Perhaps that's the difference - my car is an SS without magride. I may go back and just loosely zip tie the wire loom to give it room. I did drive around afterwards but didn't crank the wheel all the way, and you're right, that could cause extra stress to the wire.
02-20-2023, 12:40 PM | #9 |
My bad, I thought you were talking about the other wire harness that is mounted to the stock deflector on the SS 1LE. I haven't done anything with the ABS wire and don't see an issue with it.
02-20-2023, 01:46 PM | #10 | |
Shadow Gray '19 ZLE M6
I bought mine from GMPartsNow. $19/each and $9.92 shipping came out to $51.10 total.
PPF | Paint Correction | ZL1 Addons Rock Guards | ZL1 Addons Lift Pads | ZL1 Addons Feather Lite Tow Hook | JWM Smoked Sidemarkers | Wildhammer Smoked Rear Reflectors | JWM License Plate LEDs | RotoFab CAI | ADM IC Reservoir v2 | BC Forged RZ05 | SPL Toe Arms | BW Brake Deflectors | CMS Roll Bar | Schroth Profi II ASM Harnesses . Sold: '99 Trans Am (bolt-ons & cam) | '00 WS6 (bolt-ons, heads, cam, 12 bolt) | '05 CTS-V (bolt-ons, short throw) | '10 SS/RS M6 (short throw, CAI, coilovers, LTs, catback, JRE tune) | '01 WS6 YouTube |
02-21-2023, 12:42 PM | #11 |
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
Interesting. I guess with MRC the harness for it helps protect the ABS wire in this case.
On my 1LE, I drilled two new holes in the top "little" deflector scoop to mount the MRC wires, which look to, also, hold the ABS wires away from the deflector: (First picture is of the SS track deflectors showing the MRC harness and x-mas tree zip-ties; second picture is of the BW deflector - I drilled the holes right at the crevice/in the place as best away from airflow as I could determine) |
