Old 02-18-2023, 01:32 PM   #1
FirstTimeChevy23
Drives: 23 Camaro 2SS
Thumbs up Review on Non-NPP Borla S-type purchase
Bought the chrome tipped single exiting borla s-type from summit racing. Best price with a military discount ~1100 out the door. #11922
Car is a completely stock 23 2SS Camaro V8, 6spd manual.
Install was straight forward and can be done by anyone who has access to car ramps. Don't recommend a jack as you do quite a bit of wrestling. Used a Reciprocating SAW to make cuts.
Exhaust quality is good. Fit is good. This exhaust is quite. It's just a note above stock. It certainly comes alive at high rpm and burbles some, but for folks that want to hear the exhaust at all times, this isn't for you. Overall happy with it, but would of liked it to be a touch louder. 🤔
FirstTimeChevy23 is offline   Reply With Quote
Old 02-18-2023, 07:37 PM   #2
smokeybrown
Lowe's Pro
smokeybrown's Avatar
Drives: 2022 LT1
I like mine but feel it is too loud at times.
smokeybrown is offline   Reply With Quote
Old 02-18-2023, 09:38 PM   #3
db2022cs
Drives: 2023 2SS 1LE
You could get some headers and keep the Borla, that would wake it up a bit. Unless you don't want to have to mess with a tune.
2023 Riverside Blue Metallic 2SS 1LE Camaro
2021 Black Hyundai Veloster N -Sold-
2016 Grey Chevy Volt -Sold-
2018 Blue AWD Kia Stinger GT2 -Sold-
db2022cs is offline   Reply With Quote
Old 02-19-2023, 12:35 PM   #4
FirstTimeChevy23
^^^ I think that's what is in the future. Ima have to wait awhile for that purchase though ��
Old 02-19-2023, 06:43 PM   #5
lt4camaro
lt4camaro's Avatar
Drives: 2021 LT1 10 speed auto
I have had mine on for 15000 miles, it gets louder as you break it in.
lt4camaro is offline   Reply With Quote
Old 02-27-2023, 04:29 PM   #6
757Fixer
757Fixer's Avatar
Drives: 2022 1SS 1LE M6
Has anyone weighed the stock suitcase setup versus the Borla Type S? I'm curious if there are any weight savings.
2022 1SS 1LE M6 ordered 31 Jan 22
Picked up 20 Aug 22
757Fixer is offline   Reply With Quote
Old 02-27-2023, 04:50 PM   #7
lt4camaro
lt4camaro's Avatar
A non NPP dual tip OE suitcase system versus the Borla S is a 10-12 lb difference, thats it. Dual tip OE meaning, single outlet on each side.
The OE non NPP system has no valves and no motors, and single outlet on each side so it would be the lightest OE set up
Old 02-27-2023, 05:58 PM   #8
757Fixer
757Fixer's Avatar
10 to 12 pounds is not bad, I have the dual tip NPP exhaust so adding the weight of the valves might mean a weight reduction 8 pounds? I don't consider the actuators as part of the actual exhaust.
Picked up 20 Aug 22
Old 02-27-2023, 06:56 PM   #9
lt4camaro
lt4camaro's Avatar
The quad tip NPP OE suit case system with valves should heavier than my dual tip OE Non NPP with no valves by maybe 10lbs. My Borla S system is also a single outlet tip each side to match with no NPP valves. If your Borla S system is quad tipped with valves than that system will be heavier then my Borla s syetem. Do you understand now, your above remark about weight reduction didnt make sense to me.
Old 02-27-2023, 07:16 PM   #10
757Fixer
757Fixer's Avatar
When I say dual tip I am meaning per side, if that is not convention, it is what I am used to. If, as you say, comparing a single outlet per side suitcase OE muffler with a Corsa S single outlet per side muffler setup reduces weight by 10-12 pounds, I am simply guessing that comparing a stock dual outlet per side setup with NPP to a Corsa S dual outlet per side with NPP will reduce weight by perhaps 8 pounds. My exhaust is stock.
Picked up 20 Aug 22
Old 02-28-2023, 08:04 AM   #11
JoeTX
is there a video on how to install and the sound of the system? i was thinking of buying one for mine.
JoeTX is offline   Reply With Quote
Old 02-28-2023, 08:29 AM   #12
lt4camaro
lt4camaro's Avatar
Your post says you wanted a weight reference from stock OE versus Borla s not corsa s. OE Stock or not optional would be a single outlet each side and no NPP. I would think a OE NPP quad tipped versus a borla S quad tipped npp would be the same weight difference of 10-12 lbs
Old 02-28-2023, 03:36 PM   #13
757Fixer
757Fixer's Avatar
Whatever.
Picked up 20 Aug 22
Old 02-28-2023, 03:55 PM   #14
lt4camaro
lt4camaro's Avatar
Whatever.
