Old 02-18-2023, 11:17 AM   #1
jebfour
jebfour's Avatar
Drives: 2018 1SS 1LE
Another Quickjack Question
Hi All,
I’ve read every post on C6 about these and now I’m ready to pull the trigger on a Quickjack purchase. However, it appears that they have reworked their model numbers (might have been done a year or so ago – not sure).
As it stands I’m ready to go with the 5000TLX as it is only $50 more than the 5000TL, and I figure the extra frame length might come in handy at some point.
Car is an ’18 1LE and has the ZL1 Addons lift pads (non-stealth).
Anything I’m missing or need to consider before picking these up?
Thanks in advance!
Current
2018 1SS / 1LE
Previous
1967 w/ 327 & M21
1968 w/ 302 & M21
1968 RS/SS w/ 383 & M22
1986 IROC Z
jebfour is offline   Reply With Quote
Old 02-18-2023, 12:36 PM   #2
Ryanbabz71
Ryanbabz71's Avatar
Should be fine, I have the 7000xl and it works fine. Got the 7000 to handle my truck also
Sent from my iPhone using Tapatalk Pro
Ryan
Old 02-18-2023, 12:44 PM   #3
302crossram
302crossram's Avatar
Drives: 2023 Sharkskin 2SS
I really like the idea of a QJ however,
crawling under one makes me a bit nervous.
Old 02-18-2023, 01:00 PM   #4
HDRDTD
I believe that they increased the amount they raise up, but I'm not positive.
Old 02-18-2023, 02:11 PM   #5
04DetroitLS
Drives: 2022 LT1
throw a floor jack or 2 under???
NON-Ninja edit : just realized i meant jack stand not floor jack... sorry its the weekend my brain doesnt work on weekends because I refuse to pay it overtime...
04DetroitLS is offline   Reply With Quote
Old 02-18-2023, 02:14 PM   #6
302crossram
I could do that
Old 02-18-2023, 03:19 PM   #7
N Camarolina
N Camarolina's Avatar
Drives: 2021 2SS 1LE
QJ is quite solid when raised, and when set in one of it's 2 locking height positions, is not relying on hydraulics to keep the car elevated. There's a YT video testing how much weight the 5000 can hold before failing, and if I recall correctly it was way higher than 5K pounds.
I too was leary of going under the car on my quickjack the first couple of times, but now I don't think twice about it.
N Camarolina is offline   Reply With Quote
Old 02-18-2023, 03:38 PM   #8
Ryanbabz71
Ryanbabz71's Avatar
Send in someone else
Ryan
Old 02-18-2023, 04:48 PM   #9
clg82
Drives: 2020 Camaro ZL1
I have thought about these as well, what are you guys using to have the QJ touch the lift pads with? I saw a video once where someone used cut wood to put in the slots of the QJ and they said it was more stable.
Old 02-18-2023, 09:01 PM   #10
Kerry
Drives: 2019 2SS Camaro
Make sure that the pads are screwed to the pinch welds with the set screws because they can roll that's very very bad. QJ is some of the best money I ever spent saved me thousands for sure.
Kerry is offline   Reply With Quote
Old 02-18-2023, 10:22 PM   #11
willzilla
D3RPZILLA
willzilla's Avatar
Drives: 2021 Camaro ZL1 a10
I love my QuickJack I did a pretty in-depth setup and install video on the 7000TLX which works perfect lifting my ZL1 I use the zl1addons pinch weld lift point mounts with them hooked to the rear pinch welds and the second back front pinch welds.
When lifted at max height and on the locking bars I slide a set of stacked race ramp wheel cribs under the tires for extra safety in the event somehow the lock bars explode during a hurricane or something haha.
As for the TLX type series they add more lift height which is always nice! Def worth the extra few bucks. Also, I'd recommend grabbing their wall mounts which lets you mount the frames to the wall when not in use.
Here is the video I did on the QuickJack:
Here is a quick YouTube "short" video of me lifting up my Camaro (sadly this forum only puts a link to the clip and does not embed shorts for whatever reason):
https://www.youtube.com/shorts/Wn_noH7oT1w
Website: z1lla.com | YouTube: sub.z1lla.com | Merch: Shop & Etsy
YouTube Playlists: Performance Mods | Show Mods | Other Mods
willzilla is offline   Reply With Quote
Old 02-19-2023, 05:34 AM   #12
302crossram
Is there enough clearance for a creeper to be used ?
Old 02-19-2023, 08:54 AM   #13
Ryanbabz71
Ryanbabz71's Avatar
They come with rubber blocks
You can purchase other ones also. They have ph ch weld blocks (I used these on my parents toyota highlander)
Example
Ryan
Old 02-19-2023, 09:08 AM   #14
joekd
Drives: 2018 Camaro SS vert
I bought extra pinch weld style blocks off amazon and can tell you that once the car is lifted it is beyond secure
As long as you reach a locking point the car isn't going anywhere. I feel a lot safer under my cars on the QJ then I have ever felt on jack stands.
joekd is offline   Reply With Quote
