Owning SSes for 50 Years
LT1 - Change to Staggered Set
I need wheels for drag radials that are at least 9 1/2 inches wide for my LT1. Current stock wheels are 8 1/2 I think. So, I thought may be better to just buy a new set of wheels with the specs I need. But now that I think about it, on my 2018 2SS, I bought a set that the tires were not stock sizes and it caused a problem with traction control, so I finally ended up putting stock dimension tires on the front that fixed the problem.
So, since that made me a little gun shy, I wondered if I put a staggered set on the LT1 which stock, has square configuration am I going to have the same problem. I had stock dimension ILE wheels on my 2018 which looked killer and there was no problem with the staggered setup. The question: if I use the same setup on the LT1, am I going to be in trouble with traction control? Any experience from the forum?
The new ride: 2023 Camaro, LT1, Sharkskin Grey
Previous Performance Cars: 1966 Chevelle SS 4M, 2010 Corvette 6M 1968 Dodge Charger R/T Auto 2012 1SS 6M 1982 Corvette Auto 2010 1SS 6A 1984 Corvette Auto 2016 2SS 8A 1999 Camaro Auto 2017 HBM 1SS 1le 2002 C5 Corvette 6M 2018 2SS 2006 Corvette Auto 2023 Camaro LT1 |
![]() Drives: 2021 1SS 1LE [Shock] Join Date: Dec 2020
Group experience is width difference will not cause problems for the TC, it is tire height difference that gets you.
Keep overall tire height similar and you shouldn't have issues. I don't think anyone has the exact number where trouble starts, but staying below 5% seems to be safe.
I admit it, I like Mustangs.
Ex Spec Miata driver. |
#3 | |
Thanks for the reassurance. Jerry
