![]() Drives: 22 ZLE 6MT Join Date: Nov 2017
Belt suggestion for ATI lower pulley
Will probably bump up to the ATI #916105, 8.295” lower pulley. I just can’t find any belt size suggestion. Since it isn’t a massive jump in size from the oem pulley, I found the next biggest Gates belt from OEM part# K080830HD
Has anyone used this pulley size and if so which belt did you use? Thank you |
Having FUN in the SUN...
![]() Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
Hope this helps...
2022 M6 ZLE: GMS Stage.III KONG X.PORT Package + DMS Lid + GMS Rear Bumper Belly Pan + GMS Hood Bracket + GMS Flex Fuel Package + MONSTER Triple S Clutch + XDI.50% Injectors + CLICK FOR BUILD LIST or www.GRIFFIN-MOTORSPORTS.com = 915rwhp 850rwtq + E60 + 15psi
Super Stock
Drives: Chevrolet Camaro ZL1 Join Date: May 2022
The increase in size is not that much more than stock. You may want to try to throw the stock one back on and see if it'll fit when you install the larger pulley. I run a 5% and had to switch to the K080830HD one. Unfortunately it is a very obscure size and I'll never be able to run an RPM version because they don't make it. But in your case the increase is so small, its size increase may not be a huge factor.
758 HP/ 804 TQ |
#5 | |
