Old 02-14-2023, 12:04 AM   #1
Jordzns
Jordzns's Avatar
Drives: 2017 Camaro 2.0T
Camaro 1LT lug nut and center cap size
Does anyone know the lug nut size and center cap size for the camaro 1lt? (non rs). I'm planning on putting a cover or painting them black if I can.
Jordzns is offline   Reply With Quote
Old 02-14-2023, 06:21 AM   #2
ctrlz
This doesn't answer your question, but your post reminded me of this thread which demonstrates that "close is not good enough" when it comes to lug nuts!
https://www.camaro6.com/forums/showthread.php?t=608524
Old 02-14-2023, 07:40 AM   #3
laynlo15
Drives: 2022 Lt1 A10
The lug nuts are 14x1.50. Torque is 140 lbs. Not sure about the center cap.
Old 02-14-2023, 06:07 PM   #4
lt4camaro
lt4camaro's Avatar
Drives: 2021 LT1 10 speed auto
14x1.5 with a conical 60 degree seat , all the center caps will clip into the wheels. same size
lt4camaro is offline   Reply With Quote
Old 02-14-2023, 06:15 PM   #5
lt4camaro
lt4camaro's Avatar
Hey laynlo, I torqued up and seated my lugs today on the front runner and put 21 miles on the car to scrub the surface and wear off the Titties, but most of them are still there . Ran them with 40 psi and there is no bulge, happy with the tires, and 28 inches is as tall as you can go on the front.
Old 02-16-2023, 06:56 AM   #6
The Maverick
Somewhere in the Kalahari
The Maverick's Avatar
The center caps for the factory wheels are 2 5/8".
The GM center caps I purchased off eBay were listed at 67mm, but it appears these are sometimes listed as 66mm since the exact dimensions fall between those two numbers.
Old 02-16-2023, 07:07 AM   #7
ctrlz
Time for some cheap calipers off amazon
https://www.amazon.com/Electronic-Mi...xpY2s9dHJ1ZQ==
Old 02-16-2023, 07:18 AM   #8
The Maverick
Wow, those are inexpensive! That reminds me that I have my dad's old dial caliper packed away in moving boxes here. Hopefully to be unpacked this spring now that I am into a proper garage...
