![]() Drives: firebird Join Date: Jan 2010
Throttle body need tuning
I have a Katech 87mm throttle body sitting in the garage. If I throw that on my LT4 will it require tunining?
I would call and ask them, but I wouldn't think it would.
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq |
fo'shizZL1
Drives: 2017 ZL1 Join Date: Aug 2017
you should be good. might need to do the throttle body relearn
Mods being installed- oil pump, cam, ported heads, dual in-tank, Goliath and XDI, corn, etc., etc. |
![]() ![]() ![]() ![]() Drives: 2023 ZL1 Join Date: Dec 2022
I put a 100mm on my new 2023 ZL1 and didn't require a tune. But, yes it require that I unhook the battery for a minute, reconnect and drive a bit to do a throttle "re-learn"
what does the timing show at idle with the throttle body?
Moderator
That’s the question of the hour. I tried a “ported” TB by a vendor that was supposed to be better than a 103mm…absolute nightmare. Tons of negative timing at idle and the car acted possessed. I took it off and put the Katech 103 back on, problems are gone. I then upgraded to the Katech 112, also no problems.
#7 |
Oh Oh it's Friday Night!
Drives: 2018 ZL1 1LE Nightfall Gray Join Date: Jan 2018
^^^Agreed.^^^ Unhook the battery, install, hook it back up and go for a long drive. You should be good to go.
Four that wanna own me Two that wanna stone me One says she's a friend of mine... |
#8 |
![]() ![]() Drives: 2015 Camaro ZL1 Join Date: Oct 2020
The CNC ported 87mm throttle body does not require a tune.
The CNC ported 95mm or billet 103mm throttle bodies both require tuning. |
#9 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 Camaro SS 1LE Join Date: Aug 2018
I'm seeing negative timing at idle. I have a Nick William's 103, on a tuned car the TB relearn would not be a necessary thing to do correct? I suspect mine is coming from a probable MSD leak and I know the MM Wild is causing some vacuum leak because when I cap it off idle timing is much better. Just trying to make sure the TB relearn is not necessary on a tuned car.
2000 Miata - aventi storm wheels, roll bar.
2019 Mustang GT pp1 - svt pp2 wheels, mbrp cat back, sync 3 upgrade, p1x procharger + stg2 intercooler. 2018 Colorado zr2 - zr2 sport bar, showcase spare tire. 2018 Camaro SS 1LE - GM cai, black bowties, suede knee bolsters, 1le plate frame, black fuel door, dark tails + 3rd brake light, euro side markers + led's, GM all weather floor mats, velossatech big mouth, GM strut brace. 2017 Corvette Grandsport (sold) - untouched. 2006 GTO (sold) - iat relocation, air box mod, monero side marker lights. |
#10 |
fo'shizZL1
Tuning should have fixed the negative timing by adjusting the torque and airflow modeling.
#11 |
I will have to get back with you on that one!! I just installed my long tube headers and getting ready to do the rest of the exhaust and the Corsa Axle back with NPP. Then on to the sweet looking Katech valve covers with coil relocation kit, new Granatelli new coils and 0ohm plugs wires, then reassemble the rest that I took off to do all this work! So at the moment, she isn't firing up! But once she ready, I'll check the timing before any tune is done.
#12 | ||
![]() ![]() Drives: 2017 ZL1 Join Date: Jan 2017
Anyone attempting TB should observe their Zero Pedal Engine Torque and compare it to Predicted and Immediate Tq and update their Torque Model values to get their timing back in the positive values, somewhere like 0 to +10 degrees (ish). Also want to tweak the throttle body area values and if you are feeling skilled go into driver demand tables to adjust curves for improved driveability. Here is a video that touches on this topic, it is associated with changing the CAM but at the end of the day both TB and CAM are changing the airmass into the cylinder:
