![]() Drives: Canadian 2019 BLACK ZL1 Join Date: Feb 2020
État transmission Oil
Hi guys
I need to change my rear trans oil… The right oil is below… if I’m right… GM ACDelco Dexron LS 75W-90 Gear Oil 32oz As I’m french… this oil isn’t sold here… Is there another possibility ? Otherwise maybe a e website that could ship it… but not rockauto cause thé selling form is really a shit… lol I would like to have a ser with de pump system on the cork.. Thanks guys
![]() ![]() ![]() ![]() Drives: 2018 Camaro ZL1 Join Date: Aug 2018
Can you order it from Amazon? They sell it as I get mine from there. You'll need enough to fill the diff as it holds roughly 1.6 quarts.
Royal purple, Amsoil and red line are other brands you can use. Make sure that they have the slip friction modifier. |
![]() ![]() ![]() Drives: 2019 ZL1 Riverside Join Date: Apr 2020
Amsoil Severe Gear (for rear diff) - don't even bother with anything else. It always wins standardized tests - real science, not internet opinions
#4 | |
I don't know how many ZL1s have had their rear end blow up because of the fluid by using the OEM fluid or anything else within spec. But I'm going to say it's 0. |
Oh Oh it's Friday Night!
Drives: 2018 ZL1 1LE Nightfall Gray Join Date: Jan 2018
^^^Yes^^^
Four that wanna own me Two that wanna stone me One says she's a friend of mine... |
#6 | |
USCG Retired (MKC)
Drives: 2018 2SS 1LE Black Join Date: Aug 2018
The ELSD is not a traditional limited slip where the clutch pack is under constant spring tension and needs LS additive to not chatter, it has a clutch pack resembling a motorcycle clutch that is electronically/hydraulic controlled like a manual locker but variable. My point being using a limited slip oil/additive will severely reduce the performance of the ELSD as it will not lock up as intended. YMMV
#7 | ||
You need special tools to gain access to the clutch pack side and it's not a regular maintenance item like the gear side is. https://www.camaro6.com/forums/showthread.php?t=548936 |
#8 |
I just want to change the oil… no more …and as the spec … don’t want to break something or have a risky situation..
I cannot order on amazon… cause the dot com is a french site… I don’t know if I can create an us or canadian amazon account… |
#9 |
You have a few brands to go off of. See if you can find a local performance shop or a place where they dyno vehicles and ask them if they can order the fluid for you by any of these brands in the correct spec.
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '21 ZLE A10 Join Date: May 2012
french ebay?
