02-08-2023, 02:12 PM | #1 |
Drives: Camaro 2011 SS Join Date: Jan 2023
Rear View Camera Mirror
Hello , i have a stock camaro ss l99 2011 405hp , i would like to get your opinions on a camera rear view mirror do any of you have one ? are you satisfied with it ? what are the pros and cons of one? where do you get one ?
im talking about a mirror thats a rear view camera not a camera that turns on when u go in reverse. |
02-12-2023, 10:06 PM | #2 |
Funny you mention this, as I was just thinking about this today. This setup comes as an option on the 2023 Camaro. I don't know if this could be successfully retrofitted to our cars though. Maybe as an aftermarket option it could be done.
Basically you can hit a button to switch between regular rear view mirror or full time rear view camera, which takes up the entire screen of the mirror. Cool stuff.
02-12-2023, 10:46 PM | #3 |
Drives: 15 Camaro 2SS M6 Join Date: Jan 2020
there's lots of rear view monitors out there....I was thinking about getting the one made by pyle...I think they're on amazon.
Crutchfield has a bunch. This is the thread that got me interested: https://www.camaro5.com/forums/showthread.php?t=136532 |
07-07-2023, 10:10 AM | #4 | |
Drives: Mec Join Date: Jul 2023
07-07-2023, 10:19 AM | #5 |
Drives: 2012 Victory Red LFX Join Date: Dec 2012
Spam.
2018 SS wheels, red Heritage grille, actual driving lights, ZL1 strut tower brace, GM Performance billet aluminum fuel door, front grille Bowtie delete, painted red rotors and calipers, 1/4 window American Flags, splash guards, AEM dry panel air filter.
07-07-2023, 11:44 AM | #6 |
07-09-2023, 08:21 AM | #7 |
Drives: 2015 Z/28, 2015 1LE Join Date: Feb 2017
For what it's worth, I did this on my Z/28 and I love it. It is amazing on the track as I don't have to try to look through the roll bar, tint, and wickerbill. It is a pretty sweet feature for driving on the road too.
07-10-2023, 08:08 AM | #8 |
Drives: 2015commemorative vert 2SS Join Date: Oct 2013
Glad you liked it. I have had it on two of my Camaros and never used it. Found it to be for me, pretty useless. And they took out the garage door openers to install this in the newer GEN6 cars from the factory.
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded 2015 commemorative vert 2ss |
07-10-2023, 02:26 PM | #9 |
Drives: 2010 Camaro 2SS L99 Join Date: Apr 2023
Had a friend who installed one on his 5th gen that he sold, said he like it but also had problem with either glare from people's headlights and such or just nighttime driving in general, can't remember the specifics though.
Behind every scratch is a story on what not to do, and my car has a lot of stories.
07-10-2023, 02:36 PM | #10 |
Older Than Dirt
Drives: 2010 & 2013 Camaros Join Date: Apr 2010
I can't speak much for the wideview full camera mirror add-on. I have an early Ofer setup which uses only part of the mirror when backing up. Otherwise it's just a mirror.
The wife has one on her CT5-V and I have one on the GMC Denali. I like the fact the cameras are adjustable and wider field of vision. LED lamps from cars behind though will flicker at you in the camera mirrors. Kinda strange looking but I'm used to it. If I didn't already have a rear view camera and had the option to add the full view mirror to our 2010 SS, I'd say yes.
2010 2SS TE, 1 of 822/2013 Camaro ZL1 vert, 1 of 54
07-10-2023, 02:37 PM | #11 |
Is it a genuine one or just a generic one you add to the top of the mirror? I don't have any glare. Granted I don't drive the car much, so I haven't had a big truck behind me with LEDs but I know it's not any worse than having a normal mirror. Normal headlights though are totally fine with driving. And the night time is pretty clear as it is. It's not any worse than a normal mirror and looking through 5% tint. But it's no night vision. Mine is the Genuine GM Mirror and antenna. Not a generic after market one.
07-10-2023, 02:45 PM | #12 | |
07-10-2023, 05:44 PM | #13 |
Drives: 2010 Camaro SS , 2011 Colorado LS1 Join Date: Jan 2022
Having one in my Denali, I really wish I had one in the Camaro. Not sure I am ready to drop that much coin on an OEM setup.
09-21-2023, 04:05 PM | #14 |
Drives: 2012 SS Join Date: Dec 2021
unless I am missing something, you should be able to take any rear view camera and instead of it going hot only in reverse, have the power wire to a switched on source and whenever the car is on, the camera is activated.
2012 Camaro SS
