Old 02-07-2023, 12:09 AM   #1
db2022cs
Drives: 2023 2SS 1LE
Active rev match and manual gearbox quesiton
So I have the rev match on and I really like it. One thing I am not fully sure on is when downshifting into a lower gear with active rev matching on, are you supposed to quickly release the clutch? I'm assuming this is the case as the rev matching will match up allowing for a smooth downshift. Car just recently passed 1500 miles and starting to have a bit more fun with it.
In regards to the manual transmission, I was going through the owners manual and I noticed this sentence:
Shift into 1 (First) when going less than 65 km/h (40 mph).
Now my last car was a Veloster N and the gears were pretty short. I needed to get into 3rd gear before 60mph. I was always under the assumption that first gear is for taking off from a stop or a very slow start under 5mph. Does anyone ever shift into first at a lower speed if taking a turn or something, say 10-20mph? I still won't but I'm curious if others do and if not, why does the manual say this? TIA for any input.
2023 Riverside Blue Metallic 2SS 1LE Camaro
2021 Black Hyundai Veloster N -Sold-
2016 Grey Chevy Volt -Sold-
2018 Blue AWD Kia Stinger GT2 -Sold-
db2022cs is offline   Reply With Quote
Old 02-07-2023, 08:01 AM   #2
ember1205
Hot Camaro
ember1205's Avatar
One of the main reasons for rev-matching on a downshift (whether via ARM or manual control with your foot on the accelerator) is specifically to allow a quick release of the clutch without adding wear to the clutch. If you're still "slipping" the clutch when you release, you're not getting the benefit of the rev match.
I predominantly do the rev match manually. On the highway, however, I'll turn it on because I do it mostly by sound and I can't hear the motor well at 75MPH with the top down if I'm getting ready to take an exit...
Old 02-07-2023, 09:37 AM   #3
USAFS197
USAFS197's Avatar
Drives: 2018 Audi TT RS
The only time I ever downshift into first, is if I know I'm coming to a stop. Otherwise, these engines make more than enough torque to power you out of a turn at those speeds in second gear.
2018 Audi TT RS
2019 Audi RS3
About as fast as the TT RS
2019 Camaro ZL1 1LE
Sold
2018 Camaro SS 1LE
Sold
2019 Corvette Z06
Sold
Sold
Old 02-07-2023, 09:44 AM   #4
Socal Shock
Socal Shock's Avatar
Drives: 2020 SS
No, I've never shifted into first while still rolling. I've never needed to, at least on the street in this vehicle.
Socal Shock is offline   Reply With Quote
Old 02-07-2023, 09:46 AM   #5
ember1205
Hot Camaro
ember1205's Avatar
Yeah, similar here... If I'm coming to a stop, I may downshift one or two times, possibly as low as second gear. But then it just goes into "N" and I don't touch the clutch again until I'm ready to pull away from the stop and put it into "1" at that time.
Also, I believe that the page / comment being referenced actually comes BEFORE the rev-match info in the manual. It's more about starting from a stop and not having to do with downshifting into "1".
Old 02-07-2023, 10:56 AM   #6
SSEssence
Instagram: Sangstah
Drives: 2019 Camaro 1LE
When rev match is on, I usually quickly release the clutch and never shift to 1st while in motion usually, 2nd gear is sufficient.
SSEssence is offline   Reply With Quote
Old 02-07-2023, 10:57 AM   #7
Wyzz Kydd
Drives: 2018 Camaro SS1 1LE
Same here. I only use 1st from a dead stop.
Wyzz Kydd is offline   Reply With Quote
Old 02-07-2023, 11:22 AM   #8
db2022cs
Thanks for the input, glad to know I was mostly doing it right. My last few cars were all Turbo so I'm still getting used to the powerband. They were all either AWD or FWD so I'm slowly exploring the capability of the car and the characteristics for 450hp RWD car.
Old 02-07-2023, 12:29 PM   #9
JamesNoBrakes
JamesNoBrakes's Avatar
Drives: 2SS 1LE
Yes, all the time in Autocross.
2018 2SS 1LE
2023 Colorado ZR2
2022 Stinger GT-line AWD
JamesNoBrakes is offline   Reply With Quote
Old 02-07-2023, 12:47 PM   #10
jp6
jp6's Avatar
Drives: '22 2SS Camaro Convertible 6MT NPP
On regular, slower, street driving I have noticed sometimes the rev match doesn't quite match perfectly. In those cases I will let off a little slower. Otherwise I let off quick. I'd say just go by feel and if you're not experiencing any lurching then you're good to go (faster!).
2022 2SS 6MT NPP Summit White Convertible
* Skip Shift Eliminator
03/04/2022 | Spotted in-transit 2SS Vert 6MT NPP on Chevy website
03/30/2022 | Took delivery from dealer
jp6 is offline   Reply With Quote
Old 02-07-2023, 12:48 PM   #11
pzoom
pzoom's Avatar
Drives: 2021 SS 1LE SHOCK
I’ve heard downshifting to first while moving is stressful on the the synchros and transmission. I stay in 2nd until 2K rpms or so then neutral to stop. Brake pads are always cheaper than clutches.
Whether that is the best way - don’t know, but I’ve never had to replace a clutch in the past 30 years.
pzoom is offline   Reply With Quote
Old 02-07-2023, 04:06 PM   #12
BundiMan
The Nights Watch
BundiMan's Avatar
Drives: 22 ZL1 M6 Vert
You can reach 58 mph in 1st gear, so down shifting into 1st below 40 mph is the recommendation if you are going to do that.
Ordered 22 ZL1 Vert M6 Wild Cherry
2000 19 Jul 2021
3000 21 Jul 2021
TPW 8/23 24 Jul 2021
3400 30 Jul 2021
3800 26 Aug 2021
4000 1 Sep 2021
6000 14 Sep 2021
57 Days from accepted order to delivery.
19 Days from build to delivery.
BundiMan is offline   Reply With Quote
Old 02-07-2023, 05:10 PM   #13
N Camarolina
N Camarolina's Avatar
Drives: 2021 2SS 1LE
On the subject of Rev Match, I've been wondering......
The manual says it matches on both down AND UP shifts. I use Rev Match all the time and clearly see the computer raising the RPM on downshifts, but what does it do on the upshifts? Clearly you don't want to raise RPM on upshifts, so the only need for a RPM adjustment would be to lower RPM if you are going to skip shift. Buy I can't see a way for the computer to lower RPM by dampening it.
So does anybody know what it does on upshifts?
N Camarolina is offline   Reply With Quote
Old 02-07-2023, 05:21 PM   #14
ZPirate
ZPirate's Avatar
Me too. The gear spacing is pretty broad in the Camaro compared to other manual transmission cars I've owned. Between the tall gearing the torque of the LT1 you don't have to shift as often as in cars with less displacement. I typically don't get past 4th when driving around town (around 50 mph). I'm typically in 5th gear in my Z at the same speed.
2003 Nissan 350Z (modified)
2009 BMW 135i (Sold)
