![]() Drives: 2017 TT ZL1 TH400 Join Date: Dec 2018
Garage Sale /Custom TT kit $17k
Changing the build on the car. Have some things for sale. You can see the car on IG @ TT__ZL1.
$17k Full Twin Turbo kit- powder coated black 76/75 precision mirror image turbos, forward facing custom 1 7/8” headers, Plazmaman billet intake with port rails, 2- 64mm BOVs precision, 2-46mm Precision Wastegates, all the hot side is Ceramic coated high heat black, 1- A2W intercooler, 1- 5 gallon Aluminum ice tank, 2- earls water crossovers manifolds, 1- CSF radiator with -16an fittings, all the and lines for the oil feeds,water lines, coolant lines, and C02 lines. Dumps fender exit. This set up went 8.3 and made 1400 rwhp at 24psi. We could have went faster but fabricator got me in so I’m selling to go single turbo. This kit requires to relocate the fuse box and ecu, remove water pump and run electrical water pump for coolant. I did all the work it’s not that hard. Fabrication was done by a local fabricator hot rod shop. Have over$30k in the kit alone. Willing to separate Other items for sale $400 Stewart EMP pump with -12an welded ends $4500 6gen Crawford Racing Port injection Holley Dominator (3.5screen, traction control) $300 ATI Super Damper $300 LME billet front cover VVT delete (I have 2 available) $900 2600 FIC injectors (8 of them) Send me a message or text 562-325-0968 for more photos
2017 TT Camaro ZL1 / TH400 / LME 416 / LME CID HEADS / Huron TT 68/71 106 / Crawford Port Injection / Holley EFI / AEROSPACE Components fronts and rears / 15" Weld Beadlocks / Torqbyte Methanol Kit / Prometh Trunk Tank / Plazmaman Intake
TTT
Price drop..$12,000 OBO without intake
