Old 02-03-2023, 08:23 AM   #1
Pollock
LT4 M6
Pollock's Avatar
Drives: 2018 ZL1 1LE
Elite Engineering E2 Catch Can Radiator mount???
How are we mounting the E2 Catch can up front by the radiator? I have the bracket that is meant to mount by the brake booster. Thinking I might be able to make something to extend it so I can mount it on the thermostat housing bolt??
Ideas? I did buy their E2 Bracket for the ZL1 but I think its for the 5th gen. Will find out once I get it.
My goal is to run the ADM expansion tank. Or can I get the Catch can and the ADM on the drivers side together?
Sorry search isn't working for me today.
Pollock is offline   Reply With Quote
Old 02-03-2023, 08:43 AM   #2
CW3SF
CW3SF's Avatar
Drives: 2019 Chevy Camaro ZL1 M6
I mounted mine originally on the thermostat housing bolt and I had no issues with the bolt or the housing. However, I noticed that the can got extremely hot due to its proximity to the radiator hose. So I just moved it to the fuse box mounting bolt on the passenger side front of the engine. I’m really not happy with it there either. Not much space below it. I may move it again to the area just behind the rotofab intake, but I’ll have to fab up a mount for over there. Might be a spring time project.
CW3SF is offline   Reply With Quote
Old 02-03-2023, 08:50 AM   #3
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I'm not sure I'm looking at the same EE CC2 you're talking about (even though I searched, to try to be sure, and believe I am), but I have the 3-port E2, and mounted it off the thermostat housing. I don't really like it that way, but I have a pretty sturdy (1/4" thick) angle bracket I put together, and it seems to be just fine. I couldn't mount it off the strut tower because of my reservoir, but I think it's pretty much just fine. I know it works, in the least.
'20 ZL1 Black "Fury"
Old 02-03-2023, 09:58 AM   #4
2023_ZL1-AUTO
2023_ZL1-AUTO's Avatar
Drives: 2023 ZL1
I installed mine on a bracket I made from a length of straight I picked up form Home Depot. Here is my post on doing so.
https://www.camaro6.com/forums/showp...9&postcount=50
I can get a better pic later this evening you you need me to.
Old 02-03-2023, 10:07 AM   #5
Pollock
LT4 M6
Pollock's Avatar
Yes we have the same CC. So looks like you used the supplied bracket then made up a L bracket? Thats what I had in mind. Glad to know it will work.
Old 02-03-2023, 10:08 AM   #6
Pollock
LT4 M6
Pollock's Avatar
This looks like a good idea too. Would appreciate a better picture. Thanks. Will review your thread later as well.
Old 02-03-2023, 10:13 AM   #7
CW3SF
CW3SF's Avatar
That’s where I had mine and it gets smoking hot being that close to the radiator hose. Oring life will be diminished with all that heat.
Old 02-03-2023, 10:29 AM   #8
2023_ZL1-AUTO
Drives: 2023 ZL1
I've not noticed mine getting way to hot, but I don't have that many miles on my ZL1 either.
Old 02-03-2023, 10:39 AM   #9
CW3SF
CW3SF's Avatar
I didn’t notice mine until I checked it after a 30 min drive. I had a little seepage from the drain so I checked it and couldn’t believe how hot it was there
Old 02-03-2023, 10:49 AM   #10
Pollock
LT4 M6
Pollock's Avatar
Having it installed directly above the headers sounds like it would get really hot there too.
Old 02-03-2023, 11:23 AM   #11
CW3SF
CW3SF's Avatar
My headers are ceramic coated. And where I moved it is farther away from the header than it was to the hot radiator hose
Old 02-03-2023, 09:46 PM   #12
SHE'Z 18
SHE'Z 18's Avatar
Drives: 18 ZL1 - M6
So for those that have a Magnuson 2650, is there a safe / standard spot to mount the CC? I currently have my Elite CC mounted on the drivers side strut tower. However, I’m planning on a 2650 install in the next couple months and would really like to have everything ready for the CC repositioning. Thanks all… ��
SHE'Z 18 is offline   Reply With Quote
Old 02-04-2023, 11:23 AM   #13
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Pics' in my post above, in case you scrolled past them.
Old 02-04-2023, 03:50 PM   #14
Pollock
LT4 M6
Pollock's Avatar
This is what I came up with. Sorry pictures are wrong direction. I am not a computer wizard.
