Old 01-31-2023, 07:12 AM   #1
pisters
Drives: Camaro 2SS 2017 and Camaro 2021 2.0
Hard shift when braking, just 11k miles (no warranty)
I have a 2021 Camaro 2.0T 1LS with 11k miles that out of nowhere started making a noise when it is braking (downshifting) and sometimes it makes it violently. Testing the sequential I found that when I downshift from 3 to 2 in low gears it makes a BOOM type noise. I am surprised that the car being so new has problems so quickly. My car has no warranty as I am not from the USA and it is imported.
I was suggested to reset the TCM but I can't find any steps on how to do it. Can I do it with a LAUNCH scanner? What steps should I follow? Sorry for the question but I searched a lot and found nothing about procedures. I will be grateful for any help
pisters is offline   Reply With Quote
Old 01-31-2023, 09:33 AM   #2
buck50
Drives: 2021 C8, 2022 Camaro 2SS
You may want to check out the two posts below. Your car is newer and should have had these both upgraded but easy to check.
Axle half shaft bolt coming loose:
https://www.camaro6.com/forums/showt...lf+shaft+bolts
Rear axle nuts coming loose:
https://www.camaro6.com/forums/showthread.php?t=573305
Order 9/09/2021,2022 2SS, NPP, 56W whls, B04 stripe, AQJ seats, N26 strg. whl., SLN brace
3000 1/19/2022
3400 1/25/2022 TPW 1/31
3800 2/15/2022
4300 2/19/2022
4B00 3/04/2022
4000 3/8/2022
Delivered 3/9/2022
____________________________________
Order 6/01/2016 2017 2SS, NPP, 56R whls
3000 6/08/2016
3000 6/15/2016 TPW 7/18/2016
3400 7/7/2016
4200 7/25/2016
Delivered 7/28/2016
Sold May 2020
buck50 is offline   Reply With Quote
Old 01-31-2023, 09:46 AM   #3
ctrlz
How often are you slowing the car by downshifting?
As implied above this does load up the drivetrain.
