![]() Drives: 2019 ZL1 Join Date: Oct 2020
Modded A10 ZL1 60-130 times?
Hey guys, I'm wondering what 60-130's will look like on modded ZL1's. I've seen a couple manual ones on youtube, but no autos for the most part that have decent mods. I'd like to see numbers of A10 ZL1s that have north of 700whp. Would love to see Draggy's if you have it, if not, no biggie. Just genuinely curious how quick we are.
#2 | |
![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL1 Join Date: Mar 2019
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
#3 | |
2020 ZL1LE A10.
LME LT4 390 short block, CID Heads, Kong E2650, FBO. 15" conversion, Nitto 555Rii or MT ET Street R or Toyo Proxes RR. 100 octane: 1045hp/1055tq. 100 octane + Alky MAF Meth (1) 10+: |
![]() ![]() ![]() ![]() Drives: 2019 Chevy Camaro ZL1 M6 Join Date: Jul 2019
I’m sure you already know this but You’re gonna be slower than someone who is at lower altitude but with the same SAE horsepower as you because your actual hp to the ground at altitude is lower (SAE is corrected hp). When I made 710SAE in Denver my actual uncorrected hp was a little bit less than 600whp. Same mods uncorrected at sea level made 740whp.
Yes
2020 ZL1LE A10.
#7 |
#8 |
Old Gearhead
Drives: 2023 GMC Sierra Denali Ultimate Join Date: Nov 2018
I'll never understand "roll" racing.....
2023 Camaro ZL1 convertible - black - SOLD
2023 GMC Sierra Denali Ultimate - black |
#9 |
Haha, state police don't either
2020 ZL1LE A10.
#10 | |
#11 |
No, you would take 1.27 times actual measured power. But your CF in COSPs is not 27% even in August. Which town do you dyno in?
2020 ZL1LE A10.
#12 |
it was in the springs...i thought i saw something that said 27% on there haha. what would correction look like here in the springs and how do i calculate
#13 | |
2020 ZL1LE A10.
LME LT4 390 short block, CID Heads, Kong E2650, FBO. 15" conversion, Nitto 555Rii or MT ET Street R or Toyo Proxes RR. 100 octane: 1045hp/1055tq. 100 octane + Alky MAF Meth (1) 10+: Last edited by JSH; 01-29-2023 at 03:42 PM. |
#14 |
![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 1SS Join Date: Aug 2016
Yes, if the correction factor used on the sheet was 1.27, then your TRUE hp was indeed 27% less than the sheet says.
| Tags |
| 60-130, a10, modded |
