Old 01-24-2023, 07:03 PM   #1
Casey9105
Casey9105's Avatar
Drives: 2019 Chevrolet Camaro SS
2019 Camaro SS - Check Engine Light - 4 Injectors Misfiring
I have a 2019 Camaro SS with 20K miles on it. Live in Michigan.
Tried starting car last weekend and my check engine light comes on. (No issues before)
These were the codes:
P16E5 (Sensor Communication Circuit 3 High Voltage.)
P0201 (Cylinder 1 injector misfire)
P0203 (Cylinder 3 injector misfire)
P0205 (Cylinder 5 injector misfire)
P0207 (Cylinder 7 injector misfire)
What was fix?
Answer:
Took it to a Chevy dealer and they said I have chewed up wires. Possibly from a rodent? Tech said it would take minimum 2.5 hrs labor estimate. He has to remove intake I believe to get access to the wires. They are ordering all new parts instead of patching wires. I gave them the go ahead..
Wanted to share in case some one else has the same issue or has experienced it before. Thanks.
Casey9105 is offline   Reply With Quote
Old 01-25-2023, 01:06 PM   #2
easttxss
easttxss's Avatar
Drives: '16 2SS M6
When I read all the injectors on one bank, I was going to say mice chewed the wires.
Years ago had a customer's S10 Blazer towed into the shop for a no start. Opened the hood and a squirrel jumped out. That thing ate EVERY wire under the hood, including the fender mounted antennae. It cost $2000 in labor to fix it as the harness wasn't available new anymore.
David
'16 2SS M6 black on black, SW long tube full exhaust, NPP, Roto-fab CAI, ported stock TB
'16 2SS M6 black w/Metallic black stripes, Kalahari, 6 piston front (totaled 1/22/20)
'14 Fusion Titanium 2.0T
'83 Jeep Wagoneer
easttxss is offline   Reply With Quote
Old 01-25-2023, 07:42 PM   #3
PMCamaro
Drives: 22 ZL1
Just one bite II will solve all your problems. Has solved mine for years.
2022 ZL1 M6
PMCamaro is offline   Reply With Quote
Old 01-25-2023, 08:24 PM   #4
cobra30689
Drives: 2002 Z28
I worked for a Ford dealer many moons ago....we had a Windstar minivan come in with a no-start. Mice had made a home in the pocket underneath the cowl where the main engine harness went into the PCM.....and chewed their way through it. I forget what that repair cost but the owner's insurance paid for it.....not cheap.
cobra30689 is offline   Reply With Quote
Old 01-26-2023, 11:25 AM   #5
JTS
JTS's Avatar
Drives: 2023 ZL1 A10
Keep your hood open and windows rolled up , when car is stored and a light on, the little critters don't like light, my garage is like another room of the house , my place to relax , when not in use the door to house is closed and a light is always on. The garage door is open long enough to get a car in or out. A fellow years back I knew did this to all the cars in his shop , he never had issues.
2023 ZL1 A10 Shadow Gray Metallic
JTS is offline   Reply With Quote
2019 camaro, camaro ss, check engine light, p16e5
