![]() Drives: 2020 ZL1, 2017 ZL1 , 2012 2 SS Join Date: Jul 2022
2022 -2024 Body Parts
Good Morning,
I am curious to wonder if the new body parts that are on the 22 and 23s will work on any 6th gen or is there enough of a change they only work on 22-23. I want to put this front bumper on my 2019. |
Somewhere in the Kalahari
Drives: 2021/18 (de-fresh) 3LT RS Join Date: Dec 2017
I think you meant your 2018? My "defresh" DIY covers the opposite swap (2019+ to 2016-2018 front end), but it may still help answer your question. The main issue for me revolved around the headlights, which were not able to be swapped.
#3 | |
![]() Drives: 2022 SS 1LE Join Date: Jan 2014
I am looking to put the OEM bumper from a 2023 on to my 2019. I really like the looks of the new bumpers.
Long hauler
Pretty much what Subcool means then, the difference between 2019 and 2020+ front SS bumpers is the center black bar on your 2019 has the integrated flow-tie and is painted black. On 2020+ it is body-color painted and no flow-tie, instead the bow-tie is in the upper grille. You can get the 2020+ look with your original bumper, the center black piece is removable and it can be ordered based on 2020+ part numbers without the flow-tie
2016 1LT v6 - Totaled Happiness: Infinite |
This is the part that is only on the 2022 and 23s and its what I want to add to my 2019
#7 | |
2020 Shadow Gray 2SS
Now if your 2019 is an 1LT-3LT your front bumper looks different and doesn't have that part...
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... BOTH are a lot of fun to operate... |
#8 |
Yes, Its an LT and weird, every time I searched about this bumper it only showed up on 22s. I assume it should just mount up, correct?
#9 |
I believe it would fit, but the headlights are different... That is very definitely an SS bumper (2020-2023)
#10 |
#11 | |
![]() Thanks everyone for the help. |
#12 | |
Long hauler
If it does have the RS package than it's a direct swap See the difference in headlight shapes below: LT Non-RS Headlights ![]() SS (RS) Headlights ![]()
#13 | |
#14 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
It would be an expensive mod in my opinion but it can be done if you want to go that route.
