Old 01-20-2023, 03:16 AM   #1
DualSS
Drives: 22 Camaro 2SS A10
For 2019+ Bose, are dash speakers the same channel as the doors?
For 2019+ Bose, are the dash speakers the same channel as the door speakers? Or do they have their own wiring?
2022 Camaro 2SS A10
2007 Trailblazer SS
DualSS is offline   Reply With Quote
Old 01-20-2023, 04:23 AM   #2
Justcruising
Justcruising's Avatar
Drives: 2019 Chevrolet Camaro 2SS A10
I do believe they have their own channel being its a Bose system you should have 9 because you also have a center channel in the dash.
Justcruising is offline   Reply With Quote
Old 01-20-2023, 12:36 PM   #3
DamonZ28
DamonZ28's Avatar
Drives: 2020 Camaro 2SS
Per the 1st pic in this post, they are on separate channels.
https://www.camaro6.com/forums/showp...5&postcount=29
My Camaro Journal
Old 01-22-2023, 04:01 AM   #4
DualSS
Cool, thanks. I'm trying to determine if I need a 8 channel amp or if 5 or 6 channels would cut it....
2022 Camaro 2SS A10
2007 Trailblazer SS
Old 01-23-2023, 09:51 AM   #5
keep_hope_alive
Electrical Engineer
keep_hope_alive's Avatar
Drives: 2023 1SS A10 Black
You will want separate channels for each driver, as well as separate DSP for each. That way you can adjust time delay, crossover, and EQ for each since the needs will be unique for each. Luckily, you can use the stock wiring since it's separated out.
Daily Driver mileage update: 45k mi. @ Mar 2025
Old 01-28-2023, 04:38 AM   #6
DualSS
Yeah, all that work has me trying to convince myself to like the Bose, but it's just not possible. The mod bug has already bit.....
2022 Camaro 2SS A10
2007 Trailblazer SS
Old 02-05-2023, 08:28 AM   #7
activeSS
activeSS's Avatar
Drives: Radiant Red SS 1LE & ZL1
What about just upgrading door and/or dash speakers? Something with more clarity?
No EV for me!
activeSS is offline   Reply With Quote
Old 02-07-2023, 12:48 AM   #8
DualSS
According to my research the weak Bose amp would not be able to power 4 ohm aftermarket speakers properly so it wouldn't be much of an improvement. The holy grail is amplification thru means of an aftermarket amp combined with those aforementioned 4 ohm speakers.....
2022 Camaro 2SS A10
2007 Trailblazer SS
Old 02-07-2023, 08:55 AM   #9
gblaue
gblaue's Avatar
Drives: 2017 Bright Yellow ZL1 6spd
Where'd you come up with that research? It can drive down to 2 Ohms.
2017 ZL1 Bright Yellow w/ black center stripe, 6 speed, CF gas door, PDR, Navi
gblaue is offline   Reply With Quote
Old 02-07-2023, 07:02 PM   #10
Zr8000
Drives: Chevy Camaro
Stock amplifiers are severely over rated and barely have enough power to run the stock systems. That’s why the have terrible bass roll off built into the systems. The amp can’t push the system any harder. Adding an after market amp to the Bose system would probably yield better results than high quality speakers mixed in with the stock amp.
Zr8000 is offline   Reply With Quote
Old 02-07-2023, 11:04 PM   #11
DualSS
Well, sorta. As the designer of the amplifier, there are limitations that have to be dealt with. But, the statement that I was responding to was that the amplifier could not drive an aftermarket 4 Ohm speaker. This amplifier is capable of easily driving 2 Ohms on all output channels, and 1 Ohm by bridging output channels.
Back to your statement of how the amp can’t be pushed any harder. Not true. There is a lot more fire in the belly. There are many factors in what determines the system performance. The amplifier is way turned down with eq, compressors and limiters.
It’s what the car manufacturers wants, and what they are willing to spend.
What if I ask you to build me an aftermarket stereo for my car. Just amplifier and speakers. Must connect to the MOST or Ethernet-AVB bus, 10 channels amplified channels. 2x80W, 4x50W, 4x25W. 10 speakers. A DSP that can do 10 channels of 9eq stages, engine harmonic cancellation, engine harmonic enhancement, cabin noise cancellation, surround sound, phone conversation cancelllation and enhancement. Must meet 2000hours or 10 years of automotive quality requirement, meet the manufacturer’s validation requirement, FMVSS automotive safety standard requirement, CISPR-25 EMC requirements. It can’t weigh more than 3#. It has To be this small size.Oh yeah, it can’t cost more than $158. It takes a team of 40-50 electrical, software, mechanical, validation, EMC, manufacturing, quality, component, system, tuning, integration engineers to pull one project off in 2 years.
A car manufacturer, GM in this case, didn’t put their budget into the stereo, they put it into the power train and suspension.
Being an oem amplifier, with cost limitations, we are limited to 12V. Aftermarket amplifiers can employ boost supply’s to boost up to 25-35V to get more power. Boost supplies are big $$$$, take up big space, and add big weight in ferrite and heatsink. We do have systems where we boost, but those are cars with big budgets.
So, when somebody goes out and spends $600 on a NAV-TV for MOST or Ethernet AVB, $2000 on 2 4 ch amps, $700 DSP, and another $2000 on speakers and enclosures, I think $158 for the system in the car is pretty damn good. Especially, when the purpose of the car is to listen to exhaust roaring at 6600RPM.
I said "the weak Bose amp would not be able to power 4 ohm aftermarket speakers properly"
As far as what research I've done? Reading a bunch of threads on this and other forums. A couple articles here and there....
I've never claimed to be an authority on this subject, I'm not.
But you, as the designer of this amp would be the authority and you know the Bose amp's limitations and strengths. So tell us, how do we unlock all that hidden fire in the belly? It's ok if it blows up the Bose speakers, since we can just replace them with 2 ohm aftermarket ones, right?
2022 Camaro 2SS A10
2007 Trailblazer SS
