Old 01-18-2023, 10:22 PM   #1
2022csilv
2022csilv's Avatar
Drives: 2023 Riverside Blue ZL1 A10
Heat soaking and ported blowers
Has anyone had a ported blower on their ZL1? Was there an issue with heat soaking?
2022csilv is offline   Reply With Quote
Old 01-19-2023, 06:56 AM   #2
ZLE dude
Drives: '18 ZL1 1LE
Here's a bunch of threads discussing heat soak. Yes it happens and it's a very normal issue, especially if you port the blower and spin it even faster.
https://www.camaro6.com/forums/searc...chid=137924590
2018 ZL1 1LE - Summit White, PDR, Rotofab CAI, 95mm TB, CSP 2" catless LT's, JMS Voltage Booster, AEM X-series WB, DSX flex fuel sensor, Banks Data Monster, Tuned by Ted Jannetty, 5% Tint, Blackvue DR900S-2CH, Diode Dynamics lighting, IGL Kenzo ceramic coating
ZLE dude is offline   Reply With Quote
Old 01-19-2023, 07:00 AM   #3
Z OH 6
Drives: 2021 Red Hot ZL1
Upgrade the heat exchangers and add an additional coolant reservoir for more capacity, or install an interchiller. Heat soak is far less of an issue. All blowers heatsoak depending on what you put them through, the intercooler bricks and intercooler cooling capacity has the most impact on controlling the heat soak though.
Old 01-19-2023, 07:46 AM   #4
Smokin19
Drives: 19' ZL1 A10, w/pdr
I changed out the 3 heat exchangers up front with larger capacity when I did my build and have no problems.
Smokin19 is offline   Reply With Quote
Old 01-19-2023, 06:02 PM   #5
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
I think the more accurate question is, is heat soak an issue with spinning it harder. As far as i understand, porting has zero effect of heat. The issue is that most people then crank up the boost to take advantage of the increased flow. That is where the blower gets hotter, faster ans the stock cooling system can't cool the car fast enough.
My solution was as follows.
1. Larger front HX
2. 2 Gallon Fender tank
3. Heat Reflection tape on the bottom side of the blower
I know others have had good luck with the (3) HX upgrade + Upgraded Pump.
I dont have much data for you yet on the results or benefits, but I will share when i get some. So far, the set up works great.
Old 01-19-2023, 07:01 PM   #6
Z OH 6
Exclamation
1. Larger front HX
Porting the blower will add boost which will increase heat to some degree too. Ultimately, once you exceed the thermal efficiency of the cooling bricks and the intercooler loop, temps will rise rapidly. There's no free lunch.
Old 01-19-2023, 07:14 PM   #7
Rapid_blue_zl1_22
See you at the Track!
Rapid_blue_zl1_22's Avatar
Drives: 2022 Rapid Blue SS 1LE
I have a ported blower on an otherwise stock car (no tune intake and exhaust also) I haven't noticed any additional heat soak. I think the main concern is spinning the blower faster. I still have a stock size pulley for now.
2022 M6 Rapid Blue 1SS 1LE PDR (Current)
2022 M6 Rapid Blue ZL1 (SOLD)
Rapid_blue_zl1_22 is offline   Reply With Quote
Old 01-19-2023, 09:08 PM   #8
JSH
JSH's Avatar
Drives: '20 ZLE
Come on, the stock blower/engine is designed to operate in constant heat soak. If my memory is correct, close to 180F. So does a ported 1.7L, as would my current setup, if I drove it long enough.
2020 ZL1LE A10.
LME LT4 390 short block, CID Heads, Kong E2650, FBO.
15" conversion, Nitto 555Rii or MT ET Street R or Toyo Proxes RR.
100 octane: 1045hp/1055tq.
100 octane + Alky MAF Meth (1) 10+:
Old 01-19-2023, 09:33 PM   #9
Z OH 6
As long as you dont exceed the stock cooling capacity, you won't see any heat soak. People run smaller pulley setups with the stock cooling without any issue either. When you start to run more boost though and push the blower harder, cooling needs to be upgraded. It's not ONLy about spinning the blower faster, its also about boost pressure which generates heat too.
Old 01-19-2023, 09:53 PM   #10
CW3SF
CW3SF's Avatar
Drives: 2019 Chevy Camaro ZL1 M6
The heat increase from porting alone is minimal. Keep the stock pulleys and you won’t notice any additional heat soak. Mitigate that minimal increase with more cooling capacity and some e85. It’s a proven combo.
CW3SF is offline   Reply With Quote
Old 01-20-2023, 04:39 AM   #11
Z OH 6
Here's a great link that shows how much boost you can get away with before needing additional cooling. Again, whether porting or changing pullies, the stock cooling has some capacity to tolerate a mild increase in boost, but once you pass a certain point, additional cooling is strongly recommended.
https://weaponxmotorsports.com/blogs...ng-mods-needed
Old 01-20-2023, 10:06 AM   #12
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Exactly.... Every X port car I have tuned makes 3-4 psi more on stock pulleys and doesn't run any hotter. I wasn't a fan of the stock blower looking from the outside in. It wasn't until I got my hands on a few X port cars that I realized it's probably the best option out there for guys that don't plan on going 1000hp. Even the standard Kong port is decent but if you are spending the money I would go X. A little softer on the hit in exchange for a stronger top end.
Old 01-20-2023, 11:04 AM   #13
JSH
JSH's Avatar
Drives: '20 ZLE
Looking back at my logs, OEM and ported after 15 min. run at basically the same temps, which is to say, soaked.
2020 ZL1LE A10.
Old 01-20-2023, 07:34 PM   #14
Rapid_blue_zl1_22
No one here is saying that the blower isn't heat soaked after porting. We are just saying it isn't (noticeably) any worse than stock. If you put a smaller pulley on, the heat soak will increase, just like on an un-ported car.
