Old 01-18-2023, 10:59 AM   #1
WhyUMad1LE
Drives: 17 SS 1LE
Low Maintenance Cam
Want to add some chop and top end to my SS 1LE, understanding I’ll lose some low end..
This is a daily driver with 57k miles and I don’t want to be changing valve springs frequently. I‘m looking at cams under .6” lift like these:
https://www.summitracing.com/parts/nal-19303897
https://cammotion.com/gen-5-lt-camsh...218-228-114-5/
Pairing that with an MSD IM, ZR1 TB, and new OEM valve springs would I be good with basic maintenance for the next 40k? Are further upgrades required? Or is what I’m looking for unattainable..
Old 01-18-2023, 12:21 PM   #2
Katech_Zach
Katech_Zach's Avatar
Drives: 14 Camaro SS 1LE
Lift will not determine valvetrain durability. You need to go with a valvetrain package that has been verified to be stable.
Katech_Zach is offline   Reply With Quote
Old 01-18-2023, 12:23 PM   #3
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Yes that is attainable. Most would be surprised at the little difference in power between .550 and .600 lift on stock heads and induction.
Now if you were going max effort race setup with lots of RPM, ported Hi ram and what not then big lift maximizes gains.
So moral of the story is I like your approach and it should work fine for a street car that gets driven daily.
Old 01-18-2023, 08:22 PM   #4
SJFGTO
Oh Oh it's Friday Night!
SJFGTO's Avatar
Drives: 2018 ZL1 1LE Nightfall Gray
Cam Motion cams have lobes which typically are easier on the valve train. I would contact Cam Motion for a recommendation and let them spec out a cam for you.
Four that wanna own me
Two that wanna stone me
One says she's a friend of mine...
SJFGTO is offline   Reply With Quote
Old 01-19-2023, 07:09 AM   #5
tbair64
tbair64's Avatar
Drives: 2022 Camaro LT1
Call Texas speed or BTR and they can help you with cam selection.
tbair64 is offline   Reply With Quote
Old 01-19-2023, 05:06 PM   #6
SOCAL.M6.ZLE
Having FUN in the SUN...
SOCAL.M6.ZLE's Avatar
Drives: 2022 M6 ZL1 1LE
I suggest calling a company like Katech to discuss your goals, so they can spec a turn key package for you. There are alot of variables to consider when mixing and matching valve-train components.
Other items to consider while the motor is out...
1. Katech Oil Pump Upgrade
2. Katech VVT and DoD Delete Covers
3. Katech C5R Chain
4. LME Dog Bone Chain Guide
5. Sending your heads Katech for porting and assembly.
Food for thought.
