Old 01-18-2023, 10:28 AM   #1
OfficialDrod
Symbiote.1LE
OfficialDrod's Avatar
Drives: 2022 Camaro 1SS 1LE
Tick Coming from front wheels help out guys
so every time i take a decent turn and you know I'm turning a little harder then normal I hear a tick coming from the front wheels only when turning my car only has 9k miles on it anyone help me out is it my wheel bearing starting to rust?? im not sure if its a 1LE thing or just a 6th gen camaro thing so if anyone has had this issue let me know
OfficialDrod is offline   Reply With Quote
Old 01-18-2023, 10:37 AM   #2
Greg83
Drives: 2023 ZL1 M6 Sharkskin
Make sure your lug nuts are torqued correctly. Thought I read hear a while back that wheels not torqued fully were found to make some clicking noise..
2019 Porsche 911-T M6-SOLD
2020 Crush ZLE A10-SOLD
2023 Red Hot ZLE M6 ordered 5/9/23, never built
2022 Shadow Grey 1SS-1LE M6-SOLD
2023 Sharkskin regular ZL1 M6-SOLD
Greg83 is offline   Reply With Quote
Old 01-18-2023, 11:28 AM   #3
Lug nuts as stated above, or you need to take the wheels off and clean the hub surface. Hopefully that's all there is to it and the wheel bearings are still good; they should definitely be fine on a 2022.
Old 01-18-2023, 12:34 PM   #4
cdrptrks
cdrptrks's Avatar
https://www.camaro6.com/forums/showp...9&postcount=76
Old 01-18-2023, 09:35 PM   #5
Ryanbabz71
Ryanbabz71's Avatar
Definitely check the hub surface
My drivers side had a ticking when turning, found some rust cleaned and it went away
Sent from my iPhone using Tapatalk Pro
Ryan
Old 01-18-2023, 10:03 PM   #6
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
I had similar issue - tried all usual tricks, problem solved when I cleaned BEHIND the rotor hat ( aluminum in my case ). Looks like it may have been rust jacking the hub. There was some pretty gnarly aluminum corrosion back there.
https://www.camaro6.com/forums/showthread.php?t=502195
ing for grip.
http://www.motorsportsne.com/
Old 01-19-2023, 10:16 AM   #7
The Maverick
Somewhere in the Kalahari
The Maverick's Avatar
Originally Posted by Vtor_ZL1 View Post
That thread ends with an interesting thought about using a paper-thin gasket between the wheel and hub to prevent the galvanic corrosion. It would have to be moisture resistant as well in that location. Has anyone given something like that a shot?
Old 01-19-2023, 10:58 AM   #8
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
I resorted to fluid film after thorough clean up. Issue has not returned .. YET
If I learned anything owning this car: the Camaro is resilient in failing the same way more than once.
ing for grip.
Old 01-19-2023, 03:08 PM   #9
Whitespeed
Drives: 2018 1SS 1LE & 1973 Datsun 240Z
Corrosion is not the root cause of the clicking. The wheel is aluminum and the rotor hat is aluminum (at least on 1LE's). There is no galvanic corrosion there. The rotor hat is also anodized, and so will minimize galvanic corrosion between the rotor hat and steel hub. The root cause appears to be a combination of insufficiently torqued lug nuts and/or whatever grease GM was initially applying between the wheel and rotor hat. Ensure the wheel to rotor mating surfaces are spotlessly clean and the nuts properly torqued and that should be the end of clicking noise while turning.
Nigel
Whitespeed is offline   Reply With Quote
Old 01-19-2023, 09:09 PM   #10
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Psssstttt... the bearing hub is STEEL, the rotor hat is aluminum. Now do the chemistries.
Corrosion builds up between these two surfaces.
ing for grip.
Old 01-20-2023, 06:37 AM   #11
Boost Creep
Boost Creep's Avatar
Drives: '18 1SS 1LE
Proper wheel torque fixed my noise, coming up on 60k pretty soon, still quiet.
'18 1SS 1LE Black, PDR
Old 01-20-2023, 06:40 AM   #12
Whitespeed
As I stated, the aluminum hat is anodized, which prevents galvanic corrosion. That is not the issue.
But for the sake of discussion, explain the mechanism by which corrosion would cause a clicking noise?
Nigel
Old 01-20-2023, 07:10 AM   #13
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Anodized means slows, does not prevent. I can tell you with certain degree of certainty, i been there, I saw the corrosion... rust jacking can happen.
I was fully expecting a bad bearing since noise seemed to happen cyclically - as it rotated under load click, click. Hard to tell in the video, but it was very pronounced from inside cabin.
ing for grip.
Old 01-20-2023, 07:54 AM   #14
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
Found it! Here is back of brake rotor hat - notice all the corrosion marks on the anodized surface.
ing for grip.
