Old 01-17-2023, 09:54 PM   #1
FollowMyLine
Driver for Hire
FollowMyLine's Avatar
Drives: 22 Camaro 2SS 1LE M6
Great Deal on SS 1LE OEM Brake Pads
Hey everyone, I figured I would post these here. Amazon has the OEM SS 1LE brake pads (non-BCD) for $215 right now. Rear pads for $166
Amazon - GM Genuine Parts 171-1040 Front Brake Pads
Amazon - GM Genuine Parts 171-1127 Rear Brake Pads
Luan Zeqollari
2022 Camaro 2SS 1LE M6 - Wild Cherry Tintcoat
2018 Camaro 1SS 1LE - Hyper Blue Metallic - RIP 6/6/20
YouTube Channel
FollowMyLine is offline   Reply With Quote
Old 01-18-2023, 09:39 AM   #2
beworthy3
beworthy3's Avatar
Drives: 2018 Camaro SS 1LE
Ah nice, just ordered them. Thanks for the heads up!
beworthy3 is offline   Reply With Quote
Old 01-18-2023, 10:48 AM   #3
FollowMyLine
Driver for Hire
Glad to help. I saw it and was surprised how inexpensive it was. At that price point I may just pick up extra spares.
Luan Zeqollari
YouTube Channel
Old 01-18-2023, 11:28 AM   #4
beworthy3
beworthy3's Avatar
Mine are fine for now but I think at some point this season I am going to have to change them out. Couldnt pass up on the price.
Old 01-18-2023, 11:32 AM   #5
OfficialDrod
Symbiote.1LE
OfficialDrod's Avatar
Drives: 2022 Camaro 1SS 1LE
great find g thanks
OfficialDrod is offline   Reply With Quote
Old 01-21-2023, 08:16 PM   #6
Nitronut
Nitronut's Avatar
Drives: Duramax, 2018 Camaro SS 1LE
THANK YOU.
If it ain't buckin, chirpin & makin all kinds of bad noises.... then I ain't happy!
Nitronut is offline   Reply With Quote
Old 01-23-2023, 08:15 AM   #7
jgenestra2012
Drives: 2018 Camaro 2SS 1LE
Thank you for posting this deal. While my pads are good for now, couldn't pass up on the offer.
jgenestra2012 is offline   Reply With Quote
Old 01-23-2023, 09:29 AM   #8
FollowMyLine
Driver for Hire
No problem!
Luan Zeqollari
YouTube Channel
Old 01-23-2023, 10:34 PM   #9
5.M0NSTER
5.M0NSTER's Avatar
Drives: 2018 Camaro 1SS 1LE
Good find for OE pads!
Can someone holler when there is a good deal on DTC60s?
5.M0NSTER is offline   Reply With Quote
Old 02-05-2023, 10:12 PM   #10
FollowMyLine
Driver for Hire
Updated with rear pads too.
https://amzn.to/3RBuqIm
Luan Zeqollari
YouTube Channel
Old 03-15-2023, 05:37 PM   #11
desertmonkey
Drives: '17 SS 1LE
Thanks for sharing!
Quick question: Do you know if these fit the 1LE rears?
desertmonkey is offline   Reply With Quote
Old 03-15-2023, 05:50 PM   #12
Dabjbr
Dabjbr's Avatar
Drives: 2020 SS 1LE
Originally Posted by desertmonkey View Post
Thanks for sharing!
Funny you ask. I accidentally ordered those as the other ones (original rear link) weren't in stock. Here's what I found...
The link you provided is the for slightly larger ZL1 rear brakes. However, I tried to fit them in the SS1LE brakes and they did in fact fit. The pad extends just a tad further towards the wheel center about 2mm. I didn't run them (yet) as I have more life on my existing pads. However, it's strange/funny that a pad with identical compound while slightly larger is double the cost of the SS1LE pads. I'm no engineer so it's on you what you decide to do but here are some comparison images...
Notice the images where I measured the used SS1LE pad. You can see the ZL1 pad underneath. With the holes aligned, you can see how much more meat is on the ZL1 pad.
The installed image shows how the ZL1 pad hangs over the disc area by 2mm or so.
Dabjbr is offline   Reply With Quote
Old 03-15-2023, 05:56 PM   #13
FollowMyLine
Driver for Hire
Thanks for sharing!
Those are for the ZL1.
Luan Zeqollari
YouTube Channel
Old 03-16-2023, 08:52 AM   #14
FollowMyLine
Driver for Hire
Strange, this didn't show up until after I posted. My only concern with running those is the wear tab digging into the non-rotor face portion near the hub, otherwise it'll probably be fine.
Luan Zeqollari
YouTube Channel
