Old 01-16-2023, 09:15 PM   #1
18SS
18SS's Avatar
Drives: 2018 SS
Procharger P1X crank pulley
I’m looking to upgrade the factory damper with the ATI but not sure if I can still use the Procharger crank pulley that comes with the P1X? Anyone made this swap?
2018 SS, Maggie 2650, Full forged bottom end, JRE Terminator cam, Golen motors CNCed stock heads, LT4 fuel system, Gulfcoat alum driveshaft, CSP/Stainless Works 2 inch headers, Stainless Works cat back, Kooks screamers, Circle D 3800 stall converter, DSX flex sensor, tuned by Ted Jannetty, 9.27@ 147.07 MPH
18SS is offline   Reply With Quote
Old 01-17-2023, 06:16 AM   #2
Kerry
Drives: 2019 2SS Camaro
No u will have to buy a crank pulley. It will be a 8.25 vs a 7.65 so pully on the charger will need to change and probly belt size. U can go to procharger and look at the calculator to get things the same speed. U might get a 7.65 that mounts to the ati but u might as well get bigger lower as it helps with belt slip
Kerry is offline   Reply With Quote
Old 01-17-2023, 11:06 AM   #3
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
You have to get a new crank pulley. Bigger one helps with belt slip and will give you more boost, unless you put a bigger pulley on the procharger to offset it.
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock
800 SAE rwhp. 9.4 @ 145 mph.
Old 01-18-2023, 05:08 AM   #4
18SS
18SS's Avatar
Drives: 2018 SS
Thanks
Thanks for the input. Ordered the ATI pulley today.
