Roto-Fab
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
Old 01-15-2023, 02:53 PM   #1
theragtopguy
Lifetime Philly Fan
theragtopguy's Avatar
Drives: 2015 Spring Edition 2SS M-6
Internal Cabin Temperature Sensor
Have a ‘15 Green Flash, I would assume there is an internal sensor hooked into to the AC system.
Where is it?
Yes, I know about the one outside.
Thanks!!
2015 Green Flash, Delivered 4/10/15
CAI, NPP Exhaust, Short-throw shifter
BBK LT HEADERS 1 7/8”
Tune by DynoSteve via SCTx4 Tuner
One of 82 GF Ragtops built in '15 out of 811 Total
[/SIZE]
theragtopguy is offline   Reply With Quote
Old 01-24-2023, 10:03 AM   #2
theragtopguy
Lifetime Philly Fan
So nobody knows anything about this sensor?
My Climate control is weird. With heat on, it blows hot on the right side but not on the left, just regular cool air.
I was told by a shop that my compressor needs replacing also because my A/C is weak but fully charged.
They said the blend door is fine.
Any comments or observations?
Anybody at all? Bueller????
[/SIZE]
Old 01-25-2023, 07:39 AM   #3
ElderJ
ElderJ's Avatar
Drives: 2014 Camaro 1LT
How did they confirm that the blend door is fine, because it sounds like you may have the makings of a broken blend door.
ElderJ is offline   Reply With Quote
Old 01-28-2023, 05:27 AM   #4
theragtopguy
Lifetime Philly Fan
They said that they listened to it cycle and did not hear anything weird.
No crunching noises or anything.
How else can you check it without ripping it apart?
[/SIZE]
Old 01-28-2023, 08:50 AM   #5
Leo72793
Drives: 2011 2SS/RS
If the temps dont change both sides its broken. Common issue on these cars. issue really is caused by running max speed on the fan and changing the temps. the cheap design on the plastic gives way causing the inability to change temps.
•2011 Camaro SS 2SS/RS A6
•MRR M017 1le Replica Wheels
•Vararam Ram Air Intake
•Speed Engineering Longtube Headers w/ Magnaflow HF Cats
•Bo White PnP Stage 2 TB
•GPI SS2 VVT Cam w Cometic thin gaskets 10.69 compression
•Xpipe w/ Res Delete and NPP Exhaust
•Tuned By Anonymous Calibrations
•Gen5DIY Mylink Conversion W/ Backup Cam
•Morel 3 way custom speakers, Infinity 860w Subwoofers in trunk baffle
•Helix P6 6ch amp w/ 8ch DSP and P1 Sub amp
Leo72793 is offline   Reply With Quote
Old 01-28-2023, 09:24 AM   #6
0stones0
It don’t come easy.
0stones0's Avatar
Drives: 2010 2SS RS M6
No crunching noises could just mean it’s all the way broke.
Some reading for you.
Heater Blend Door Forum Database
0stones0 is online now   Reply With Quote
Old 02-03-2023, 08:28 PM   #7
theragtopguy
Lifetime Philly Fan
I ordered the heater hose bypass.
Today, turned it on. Crazy hot air right side, cool air left side.
Hoping the bypass helps, I don’t need heat here in Florida.
[/SIZE]
Old 03-28-2023, 02:04 PM   #8
theragtopguy
Lifetime Philly Fan
Ok, clamped the heater hose and I have cold A/C again!!!
I have the bypass hose, will put that on eventually.
[/SIZE]
Old 03-29-2023, 11:20 PM   #9
RaycinSS
RaycinSS's Avatar
Drives: 2015 Camaro Z/28
There is a temperature sensor located near the front passenger side footwell slightly above where the passengers left foot would rest near the center console. Quarter turn to the left and you can slide it out and insert a bore scope and cycle the heat/cold knob and actually see if the door is there and functioning properly. Mine had broken and fallen down into the housing. I had the same issues as you described. The actuator was still working and making noise but nothing was attached to it. I don't have faith in your shops audible diagnosis but I do have faith in being able to visually inspect it. It takes less than 5 minutes to check this yourself. Search youtube there is a good video there to help.
RaycinSS is offline   Reply With Quote
Old 03-30-2023, 08:13 PM   #10
theragtopguy
Lifetime Philly Fan
Thanks! For now I clamped the heater line shut and I have good AC again! I have a bypass ‘u’ hose if I can get at the back hose clamp.
I live in FL and don’t need heat anyways.
[/SIZE]
