Old 01-12-2023, 12:07 PM   #1
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
Reverse Camera not working - Fixed
I’ve seen a variety of fixes for the backup camera going out, usually going back to stock taillights or stock side markers which unfortunately did nothing for me. My case was I began having issues with video feed and one day it stopped altogether, leaving me with a blank screen whenever I tried the reverse camera. See below:
https://youtube.com/shorts/TgxuNSDoWlA?feature=share
After coming back I read that the connector can cause issues with dirt or grime, I unbolted the few screws on the rear left of the car and found two connectors. Looking at one it had noticeable cables rubbed:
I reattached those two cables with solder and heat shrink, then wrapped the entirety of the exposed cables with electrical tape and now it’s working as OEM!
2016 1LT v6
- Totaled
Happiness: Infinite
Old 01-12-2023, 06:08 PM   #2
DamonZ28
DamonZ28's Avatar
Drives: 2020 Camaro 2SS
Nice work!
My Camaro Journal
Old 09-11-2025, 04:10 PM   #3
CRoyall
CRoyall's Avatar
Drives: 2016 Camaro V6 LT
Thanks!
Thanks for the info and the video. Very helpful!
CRoyall is offline   Reply With Quote
Old 09-11-2025, 04:47 PM   #4
Bumbleboy92
Long hauler
No problem!
I actually revisited this area on my 2022 and noticed that the two cable plugs are held up against the body with clips. I’m both my cars the cables were not hooked up to the clips which caused the rubbing, thankfully nothing had started rubbing yet before I found out.
2016 1LT v6
- Totaled
Happiness: Infinite
camera, issue, reverse, solved
