Old 01-11-2023, 11:39 AM   #1
asthmamax11
asthmamax11's Avatar
Does anyone have a Camaro specific JMS fuel pump booster write up ?
Hey guys
I'm going to be installing the JMS fuel pump booster soon and was wondering anyone had a more Camaro specific write up available.
Or maybe some tips on where you mounted yours, etc.
Thanks alot!
16 1SS M6 White
Magnuson 2.3 Heartbeat
Roto Fab
Hurst short shifter
#'s coming soon
Riaction coilovers
1LE sway bars
BMR mm
BMR chassis brace
02 Z28 M6 35th anniversary
80k miles
T-tops
Leather
Bolt ons
Daily Driver
Old 01-11-2023, 11:54 AM   #2
18.2SS.1LE
18.2SS.1LE's Avatar
Drives: Chevrolet Camaro
I just finished mine up over the weekend. Referenced this thread: https://www.camaro6.com/forums/showthread.php?t=552426 and Jannetty's directions here: https://jannettyracing.com/pages/jms...er-gen-6-guide
PM me if you have any issues and I can try to help.
Procharger P1X, CSP Big Boy Cam, CSP Headers, LT5 Throttle Body, MSD Intake, LT4 HPFP, LT4 Injectors, JMS BAP, 93 + Boostane - 750+WHP
18.2SS.1LE is offline   Reply With Quote
Old 01-11-2023, 12:01 PM   #3
Here is a slightly more detailed writeup with many photos, courtesy Kris G @ Jannetty Racing.
Old 01-11-2023, 12:09 PM   #4
18.2SS.1LE
18.2SS.1LE's Avatar
Head to the store first and pick up a 30A micro fuse, the JMS comes with a mini fuse that is too large.
Old 01-11-2023, 12:30 PM   #5
adamjwilson
Drives: 2022 Camaro 2SS A10
I have a quick question regarding the JMS fuel voltage booster... I am installing the DSX aux fuel kit, and inquired with my speed shop about this unit as well. They recommended the DSX kit only, and not the JMS unit. I do see some shops use both the DSX and JMS units together. (for under 1000 whp of course) Not sure if there is any advantage to using both together, but it seems like most on the forum is using one or the other. Thoughts?
2022 Camaro 2SS/ Whipple 3.0 / 2"Headers/ PRC LTX Heads/ Forged Internals/LT4 fueling/ DSX Aux/
DSX Flex Fuel/ Meth Injection/ Katech 112 TB/ RotoFab Big Gulp/ Corsa NPP/ Various exterior mods
adamjwilson is offline   Reply With Quote
Old 01-11-2023, 01:33 PM   #6
asthmamax11
Yes!
I saw that in SteelRob's video
I appreciate the links and offer
16 1SS M6 White
Roto Fab
Hurst short shifter
#'s coming soon
Riaction coilovers
1LE sway bars
BMR mm
BMR chassis brace
80k miles
T-tops
Leather
Bolt ons
Daily Driver
Old 01-11-2023, 01:44 PM   #7
LT1ornothing
Drives: 2020 LT1 M6
So with the DSX kit, some of the guys who race on road courses have discovered that fuel starvation can occur when the fuel level in the tank is below a certain point AND hard turns are being taken. The JMS voltage booster allows the pump in the tank to momentarily increase the maximum amount of fuel it can deliver, such as when you are in boost.
[SBE] ECS NOVI 1500 supercharger, 2" Longtube headers, flex fuel, LT4 injectors, LT4 HPFP, baro breakout
Tune date and results to be determined
Old 01-11-2023, 01:54 PM   #8
adamjwilson
So there is really no advantage to this 'in normal' boosted applications for both. I don't race on road courses, but understand your reasoning here.
Old 01-11-2023, 02:42 PM   #9
LT1ornothing
Drives: 2020 LT1 M6
The advantage of the dsx kit is the additional volume of fuel it can draw. The advantage of the JMS pump booster is that it can provide a little extra fuel in a more OEM style of fuel delivery.
Old 01-11-2023, 03:05 PM   #10
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
My brother runs JMS on stock pump a long with Cordes Auxiliary on his C7Z. It works fine on his car which is over 1k whp on E60. For anything 900 ish or lower just the Aux pump is likely fine on its own. Long as the pressure doesn't drop then you have enough fuel. My guess is those running JMS and Aux likely started with JMS and ended up needing more fuel as they increased power(as my Bro did), then added the Aux pump.
Old 01-11-2023, 06:02 PM   #11
Sillysspeed
Drives: 22 LT1
So is this to regulate voltage or should you just get a bigger in tank pump than lt4 and skip the jms?
Sillysspeed is offline   Reply With Quote
Old 01-11-2023, 09:06 PM   #12
LT1ornothing
Drives: 2020 LT1 M6
The answer to your question depends on your end goals, fuel type and your set up.
Old 01-12-2023, 07:41 AM   #13
Sillysspeed
Drives: 22 LT1
we used to always just put a bigger intank pump in. Most recently on my 4th Gen I had 1 450 walboro in tank and then went turbo and added another. In this car people want you to add a lt4 in tank (don’t know rating) and then add a jms booster on top of that. Why not just do a 450 or 525 in tank?
Old 01-12-2023, 07:58 AM   #14
LT1ornothing
Drives: 2020 LT1 M6
Most people shooting for huge power just go for the Fore triple pump system.
