FS: $5,800 Gen6 fuel parts LPE HPFP, LPE in tank, 44% cam, Vaporworx Controller
$5,800 for everything
Will not separate I am sell my DI fuel parts that took almost a year to get. Everything is brand new. I was planning on a 1000hp build and 60% injectors (not included) Included is the following: LPE High Pressure Fuel Pump 12mm big bore New Style LPE in-tank fuel module (upgraded with twin Ti 525 pumps and -10AN feed port Included a 3/8” Quick connect fitting for return if needed. It comes with a complete modified transfer unit to retain the factory transfer over the hump in the tank. Cammotion custom grind 3-bolt cam with the largest possible fuel pump lobe VaporWorx Ally controller for the Gen 6 Camaro. It runs one pump on the Factory FCM and piggybacks to control the second pump as needed. I included the fitting and adaptor to tie in the factory fuel pressure sensor near the tank. $5800 is pretty firm. I have more than this in taxes and shipping. I prefer to sell in person to avoid paying transaction fees. These are all personal parts, but I can sell though my business if needed. You may have to pay sales tax depending on your location. I am located in Williamson, GA which is about 20min from Atlanta Motor Speedway Last edited by Razor Edge Customs; 01-12-2023 at 12:03 PM. Reason: Added information |
![]() Drives: ZL1 1LE Join Date: Oct 2023
I dont need the cams but Just wanted to know about the High pressure fuel pump. Or would you still not separate?
I’ll sell the HPFP, and in tank pump for $4k. The 44% cam lob will get all the fuel possible out of that HPFP though. I’ll do the HPFP, in tank fp, and cam for $4300. I have about $5500 in those parts
Isnt the Fuel pump it self 3k brand new? Sorry a bit new to this I tried to do some research.
| Tags |
| cam, camshaft, controller, fuel pump, lpe |
