Old 01-05-2023, 10:39 AM   #1
Badmojo
aka BeastZL1
Badmojo's Avatar
Speed Bleeders One Man Brake Fluid Change
I've installed these on two cars and love them. No pumps or special tools are required for one man brake fluid changes.
2019 Camaro ZL1 1LE
Racing for ALS Youtube Link
Old 01-05-2023, 09:03 PM   #2
N Camarolina
N Camarolina's Avatar
Drives: 2021 2SS 1LE
Thanks for your suggestion. To each their own. I'm concerned about the safety of brake system should the one way valve ever fail while my car is being driven on the track.
Using a pressurized dry tank hooked up to the brake fluid resevoir is only minimally inconvenient and allows for an easy one man brake job using the OEM bleeder valves on the Brembos.
N Camarolina is offline   Reply With Quote
Old 01-05-2023, 10:04 PM   #3
Msquared
Msquared's Avatar
Drives: Chevrolet SS 1LE
The Speed Bleeders are not relying on the check valve to keep them sealed once you tighten them back down. Instead, the tapered end of the bleeder screw seals against the tapered seat in the caliper body, just like with the stock bleeder. In fact, the stock bleeder is functionally just like the Speed Bleeder except with no valve - just a straight-through hole! So if you don't trust the Speed Bleeder to seal, then you don't trust the stock bleeder either. The only thing the one-way check valve has to seal is the low-pressure ambient air, to keep it from entering the caliper when the pedal is returning upward from a pressure stroke.
My only question in the past has been if the Speed Bleeders might allow some air to seep in through the threads when the pedal is returning upward. Once you loosen the bleeder so that the taper isn't sealing, regular threads wouldn't completely seal out air. However, I was looking on their site and the thread sealant the bleeders come with is said to keep the threads sealed against air infiltration. At some point, it will wear off if you bleed frequently, but they sell a bottle of the sealer so you can reapply it. Makes sense to me.
I still will use my Motive just because I have it and it eliminates any worry about running the master cylinder dry. But the Speed Bleeders would be an interesting alternative.
Matt Miller
2020 SS 1LE
Msquared is offline   Reply With Quote
Old 01-05-2023, 10:17 PM   #4
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
The valve is only active when bleeding, otherwise its closed just like solid bleeder.
There is another version that was made to get around patent w ball / spring at end, but same principle. If bleeder is TIGHT, there is NO FLOW - much like ALL bleeders.
MS Paint illustration for LOLz
ing for grip.
http://www.motorsportsne.com/
Old 01-06-2023, 12:03 AM   #5
Msquared
Msquared's Avatar
Point of order: you and I agree on the main point, but there's no such thing as a solid bleeder. A standard bleeder is just like the Speed Bleeder, but without the ball and spring in the orifice. But it still has the orifice.
Matt Miller
2020 SS 1LE
Old 01-06-2023, 12:22 AM   #6
20Bluezl1
I use my Motive bleeder and have no issues with bleeding. Now I due have to say snice there Stainless it might be a good idea to replace snice they should be stronger. Pretty expensive at $15 a pop. As Msquared said it's a good thing they sell the sealant snice I do bleed alot. Might not be a bad idea also to use it on the stock bleeder.
Old 01-06-2023, 09:03 AM   #7
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
All bleeders have an orifice - requires for them to be a bleeder and not solid bolt.
Speed bleeder include check valve of sorts to prevent air from going back in when you lift off the brake pedal. Thread sealant is there to prevent air from sneaking by.
Not sure where your hang up is but these things have been around for 25+ years.
ing for grip.
Old 01-06-2023, 06:52 PM   #8
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
What size is the Brembo calipers?
Orange Krush II
1LE Front sway bar, Splitter, shocks and struts, Z28 dual mode mufflers, Intake, UCA Bushings, and Toresen 3.91 Diff. 1 piece DSS Drive Shaft, ZL1/C7 Calipers, and 32mm JPSS Rear Bar. ASC race spec splitter and wicker. 6th Gen M017 Wheels. Stainless Works 1 7/8 LTs. DSE and PAFDT Suspension components.
olblue75 is offline   Reply With Quote
Old 01-09-2023, 11:31 AM   #9
Badmojo
aka BeastZL1
Badmojo's Avatar
Part Number for a 2018 Camaro ZL1 1LE with Brembo Brakes (same for all GM cars with the same Brembo Calipers: Corvette, Cadillac CTS-V) SB1010S-SS
2019 Camaro ZL1 1LE
Old 01-09-2023, 11:40 AM   #10
Badmojo
aka BeastZL1
Badmojo's Avatar
I went with Speed Bleeders after I had a factory bleeder shear off and I couldn't extract it. The stainless steel Speed Bleeders will be more durable and less likely to break off. They do not have a relief area at the top of the thread and the hex area is beefier. If you are using factory bleeders and using the old fashion method, then I would replace the bleeders occasionally. If they snap off, they are nearly impossible to extract from the aluminum caliper. Don't make my mistake and try to extract them on the car. Pull the caliper and take it to a machine shop.
2019 Camaro ZL1 1LE
Old 01-09-2023, 12:45 PM   #11
cdb95z28
cdb95z28's Avatar
I've had success extracting broken bleeders. Use a sharp 17/64" drill but and only drill a short amount. And getting it centered is very important too. If we drill to deep or offset just a little then we risk harming the caliper itself. I then take a can of electronics aerosol duster and turn it upside down so it is super cold air coming out. You can also buy the aerosol cans that are designed to expel cold air. I will chill the broken bleeder to contract it and help it break free. I then gently tap in an easy out like the type pictured below. Proto #9524. Grab a small adjustable wrench and gently turn to remove.
"KEEP THE FAITH"-Fbodfather
Old 01-15-2023, 10:56 AM   #12
cvp33
America FVCK Yeah!
cvp33's Avatar
Drives: 2024 Z06
Russell’s 639630 should fit as well. The best deal I could find was CarID on Ebay.
1997 Z28 Anniversary Edition SOLD
2004 GTO ORDER CANCELLED
2004 CTS-V SOLD
2005 CTS-V SOLD
2006 300C SRT-8 SOLD
2010 CTS-V SOLD
2012 CTS-V coupe SOLD
2013 ZL1 vert SOLD
2016 Callaway Z06 SOLD
2019 Z06 SOLD
2021 ZL1 1LE SOLD
cvp33 is offline   Reply With Quote
Old 01-15-2023, 10:17 PM   #13
20Bluezl1
Are these. Speed bleeders sold individually or come In a pack?
Old 01-15-2023, 11:17 PM   #14
Vtor_ZL1
Who Needs to KNOW?
Vtor_ZL1's Avatar
Drives: 18 ZLE
I *know* I have bunch of them, but no IDEA if i bought them individually or in sets.
Was def handy tool when help was scarce! Most likely sold by each.
ing for grip.
