![]() Drives: 69 Chevelle SS & 22 Camaro SS 1LE Join Date: Dec 2022
Best place to mount Radar Detector?
Being that the windshield visibility is a bit "Tight"...
Where have you folks found to be the best place to mount your Radar Detector? |
Drives: 22 ZLE M6 Join Date: Jul 2014
I recommend using a Blendmount radar mount with a wire tap for power from your mirror. That’s how I have my Uniden R8 set up and it’s really clean looking.
+1 for Blendmount, it's expensive but highly adjustable, sturdy and obstructs driver vision very little, plus it leaves the windshield clear (a requirement in some states).
![]() ![]() ![]() ![]() ![]() Drives: '16 Camaro SS 6 spd manual transm. Join Date: Aug 2012
Below the rear view mirror
'16 Camaro SS
Prior cars: '14 Corvette C7 Stingray Z51 '14 Camaro ZL1 w/. Recaro seats '11 Mustang GT 5.0 w. track package '02 Porsche 911 Carrera '05 Infiniti G35 coupe sport |
![]() Drives: Chevy camaro Join Date: Jan 2022
I use a small mount with 3m tape at the upper edge of the windshield along side my mirror, Then a wire tapped into the seatbelt light. My detector is an Escort Max.
SOLD - 2017 Camaro 2LT RS Convertible 2017 GMC Arcadia Denali |
+2 for Blendmount. Or get a cheap mirror mount off Amazon & a wiretap cable from Gen5diy.
Soler DLX Bluetooth Throttle Controller / OFFKAT Smoked LED Side Marker Lights / Blue SS emblems on front & rear / Wildhammer Rear Dark Reflectors / Trim Illusion Gloss Black Door Handle Covers / eBay Black Fuel Door / Screaming Chicken Fender Hash Marks / Color-Matched G2 Caliper Paint CT Sounds Tropo 10" Sub / Down4Sound MM1000 Mini Maxx amp / JL Audio LoC-22 line output converter / Sub Thump Plug N Play T-Harness With ANC Defeat Harness Kit My Camaro Journal |
#7 |
![]() Drives: Camaro 2SS 1LE 6MT Join Date: Dec 2023
Plenty of example information in this thread too.
https://www.camaro6.com/forums/showt...=607133&page=3 |
#8 |
As close as you can get it to the top of the glass, just left of the mirror base, such that the visor barely misses it. I always drive with the visor down. If you stand in front of the car, the mirror, detector, and visor blend together.
2020 ZL1LE A10.
LME LT4 390 short block, CID Heads, Kong E2650, FBO. 15" conversion, Nitto 555Rii or MT ET Street R or Toyo Proxes RR. 100 octane: 1045hp/1055tq. 100 octane + Alky MAF Meth (1) 10+: |
#9 |
Having FUN in the SUN...
![]() Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
Its a bit more expensive, but I highly recommend an integrated kit from K40! I did the install myself to save $$$, and have been super happy with the results... and best of all, nothing hanging in the window, all hidden and great coverage!
#10 |
![]() Drives: '23 LT1 & '24 GMC Canyon Elevation Join Date: Feb 2023
I just clip my Valentine 1 V2 on the passenger sunshade. I only use it out on the open road, never around town. Which is not very often.
#11 |
L8ap3x
You have lots of great suggestions here.
+1 on the generic blendmount off eBay. I run an R8 with JBV1 and a V1G2 with HR. I also have an ALP laser jammer system. There is a great radar detector forum with highly knowledgeable folks who answer these types of questions and offer suggestions. Rdforum.org Vortex Radar is also a great channel on YouTube. His video information is highly valuable and he is known to be a gold standard of non-bias info/research/testing . It's a rabbit hole! Have fun.
"Manuals win hearts. Automatics win races."
2018 2SS 1LE HBM 6M |
#12 |
![]() Drives: 2022 Camaro SS 1LE Join Date: Jan 2024
I clip mine on the dashboard with the 3M Scotch heavy duty "hook and hook" mounting tape (you can get it from Home Depot and such: https://www.homedepot.com/p/Scotch-1...PESF/306769390 , they have it in multiple formats). The flat dashboard is very convenient for this. And at autocross I put the GPS receiver onto the same mount instead. I have mounts like this in all my cars, so for me it's a standard fit, anything can be clipped anywhere.
If you're not particularly worried about laser, you can just put the radar detector into a cupholder. I do this in the rental cars, it gets the radars just fine. It even beeps about laser but obviously with less sensitivity. Incidentally, I do have an embeddable Passport detector sitting around, but it's been sitting around for a dozen years, ever since I've sold the truck where I had it mounted first. Mind you, at the time the truck wasn't my first choice either but it turns out that finding a place under the hood with sufficient space and forward visibility for the head unit is difficult, the truck was the only one with the room. Not to mention all the pain with wiring. If they couldn't make the underhood unit smaller, they should have at least made it short and wide instead of long and narrow. |
#13 | |
Its also expensive, but less so than a wreckless op ticket for 25 mph over the posted speed limit. |
#14 |
![]() Drives: 2019 2SS Convertible Camaro Join Date: Mar 2012
Although I liked the detector mounted below the mirror in my Gen5, the video mirror has less mount room so decide to use this as well. I have it mounted as high in front of the rearview mirror as I can without obstructing my view of the screen. Actually much less obstructive to the view and I like it better. I also use the DIY5Gen5.com harness. Works perfectly with a video on how to install.
\(^^^)/ <--A Smile From He11
Escort 360 MAXX w/DIYGen5 hardwire Harness K&N AirCharger Cold Air Intake Sound Tube Delete |
| Tags |
| camaro, detector, mount, radar |
