Old 12-26-2022, 02:19 PM   #1
Sephx1
Sephx1's Avatar
Drives: 18 ZLE, 18 SS1LE, 16 SS, 23 ZL1
Pirelli P-Zero 18” slicks
Just got these used slicks mounted up on new Apex SM-10 wheels 18x11 and 18x12 for the ZLE. 305/660/18 front and 325/680/18 rear. Way cheaper than GY3R’s. Looking forward to seeing how they do once I get some heat in them.
Sephx1 is offline   Reply With Quote
Old 12-26-2022, 09:02 PM   #2
Baddawg53
Drives: 17 hyper blue 2SS M6
They look great! I've been eyeing those tires from a distance, not quite ready for slicks though. I have the same wheels except square 18x11.
Baddawg53 is offline   Reply With Quote
Old 12-27-2022, 07:35 AM   #3
iwk2much
Drives: ZLI 1LE; 992 S; GLE 450, Denali HD
You will love them, within a lap, you can lean on them unlike the 3R's. They have more sidewall flex so you car will have more lean but try to get past that feeling, the tires will stick!
iwk2much is offline   Reply With Quote
Old 12-28-2022, 05:18 PM   #4
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
the sidewalls are more compliant as stated and grip is excellent similar to a 3R. Once you get used to the slightly "squishier" feeling in transitions, you will like them. A 3R definitely feels stiffer and I would say grip is pretty equal and it depends upon how many heat cycles the tires have as to the grip available. They do come up to temp quicker as stated also.
Old 12-28-2022, 06:05 PM   #5
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
yea no slicks or 18s for me yet lol cant drive to and from the track on them and no truck/trailer yet !
Old 12-28-2022, 07:25 PM   #6
sr71bb
sr71bb's Avatar
Drives: 2019 Camaro Z-28
suggestions
Run them at 24-26PSI cold pressure. Normally you would want to run them MOUNTED with the LETTERS IN because typically they made laps with the LETTERS mounted to the OUTSIDE as is the sponsors requirement usually
Dont let them get above 32PSI Hot pressure. Typically there will be a 6PSI difference between cold pressure readings and hot pressure readings. In SUPER HOT summer conditions I have seen as much as 10 PSI difference. These will be a little quicker than GYSC3R tires but will last considerably longer. They LIKE alot of NEGATIVE camber. I run -3.7 front and -3.0 rear.
They will heat cycle out BEFORE you will see those wear indicators disappear so ALWAYS check them after a track day. I usually get 3-4 full track days out of a set.
2019 SS 1LE BIG NA A10
Eagles Canyon Raceway 2.7 CCW Below
https://youtu.be/c9M5UHDftcA
4-15-23 at SCCA TT U1 Class
MEGA Thread on THIS car:
https://www.camaro6.com/forums/showthread.php?t=602092
Retired Cars BELOW:
1973 Camaro, 1969 Camaro, 1969 Camaro SS RS
2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10
sr71bb is offline   Reply With Quote
Old 12-28-2022, 08:50 PM   #7
max pl
Drives: BMW M3
you get 3-4 days out of scrubs or new?
max pl is offline   Reply With Quote
Old 12-28-2022, 09:31 PM   #8
sr71bb
sr71bb's Avatar
Out of SCRUBS. I have never run NEW. I do run a SQUARE set up however which does help some.
Retired Cars BELOW:
Old 12-28-2022, 09:53 PM   #9
Sephx1
Sephx1's Avatar
Great info, thanks!
Old 12-28-2022, 10:16 PM   #10
Christian1LE
Drives: 2004 BMW 330CI, 2022 1SS 1LE
Nice! I need to order some and get them mounted(already have wheels camber plates) . Want to do nasa tt this year hopefully starting at vir.
Christian1LE is offline   Reply With Quote
Old 12-29-2022, 08:00 AM   #11
sr71bb
sr71bb's Avatar
Great info, thanks!
No problem. Also I run 305 660 18 square. I tried 305 680 18s on the rear but my car is quicker with more neutral handling with the 660 height tire on all four corners
Retired Cars BELOW:
Old 12-29-2022, 06:29 PM   #12
max pl
Drives: BMW M3
I only get 3 to 4 days out of new R7s so thats positive to hear considering new R7s are $1k more than scrub DHBs. I also run square.
I hear that scrub DHBs are as fast as new R7s.
Old 12-31-2022, 03:13 PM   #13
seanblurr
seanblurr's Avatar
Drives: ZL1 1LE
It's very hit or miss with the scrubs, I used to run them a bit. I had one set only last me 2 sessions, another a full day, and one slightly longer. The biggest downside with scrubs.
seanblurr is offline   Reply With Quote
Old 01-24-2023, 07:27 PM   #14
Pollock
LT4 M6
Pollock's Avatar
Drives: 2018 ZL1 1LE
That's a lot of camber. I run neg 2.8 up front and feel it's perfect. Neg 2.0 in the rear but feel I need more. I have oem sized 18s. Not square
I also start at 23 psi cold.
Pollock is offline   Reply With Quote
