Old 12-26-2022, 01:03 AM   #1
Sortiez
Drives: Camaro LT 3.6L
v6 differential swap?
Idk where to post this to get the best advice, but I want to swap my current open dif in my 2017 camaro Lt 3.6 auto v6 for a LSD. I’ve heard it’s possible to swap it for the ss one but i’m not sure. Does anybody know a LSD that would work? An aftermarket if possible i don’t want the oem.
Sortiez is offline   Reply With Quote
Old 12-26-2022, 09:45 AM   #2
TP2SS
TP2SS's Avatar
Drives: 2016 2SS Convertible
From what I've read here over the past couple years, there are no aftermarket 6th gen diffs (at least bolt-in), or gears, available. There are plenty of folks running very high HP 6th gens with OEM diffs, so I'm not sure why you have an aversion to an OEM unit. There are plenty of listings when I did a Google search for used 6th gen diffs, that's probably your best bet.
The only aftermarket thing that came up in a quick search I did was that Eaton makes a carrier for many cars/trucks, but the only one I found on that website was for a 5th gen (listed as a 218mm) Camaro. There are other "GM" type models also, but I didn't click on all of them to see if any were 6th gen compatible.
The ratio is different for auto vs manual cars as the auto low gears are so low that even a 2.73:1 rear can still launch the car. If you put a manual (something like 3.23:1 IIRC) in an auto, you're going to be WAY too low in 1st on launch and your MPG is going to go to crap!
Hyper Blue/Ash Gray
A8
Magnetic Ride Control
Dual Mode Exhaust
2019+ version Split Spoke Silver Wheels
Navigation
Silver Rally Stripes
TP2SS is offline   Reply With Quote
Old 12-26-2022, 03:21 PM   #3
Sortiez
do you have any idea of what ratio my current dif would be?
Old 12-26-2022, 09:46 PM   #4
Need4Camaro
Drives: '17 Camaro 2SS & '99 Camaro Z28
Its not possible to have taller gears installed in the 6th Gen??
Need4Camaro is offline   Reply With Quote
Old 12-27-2022, 12:03 AM   #5
TP2SS
TP2SS's Avatar
I believe the A8 comes with 2.73:1
Hyper Blue/Ash Gray
A8
Dual Mode Exhaust
Navigation
Old 12-27-2022, 12:19 AM   #6
It's 2.77:1 for the A8 (except when mated with the I4 engine where it's 3.27:1) and 2.85:1 for the A10.
Old 12-27-2022, 06:49 AM   #7
wnta1ss
Drives: 2017 Camaro 1SS
Note, the 2.85:1 ratio was only used in the eLSD, just the ZL1 A10 coupes and the SS/1LE with the A10 had the electronic diff. SS or LT1 models with the A10 still have the 2.77:1 ratio limited slip diff like the earlier A8s did, as does the convertible ZL1.
Old 12-27-2022, 10:25 AM   #8
TP2SS
TP2SS's Avatar
I knew it was 270-something but was too lazy to look it up! Thanks for the correction! Wasn't aware the I4 used a 3.27:1. I guess the OP could use an I4 or M6 version diff, but his MPG is really going to suffer! Plus the speedo would be off. If it were me, I'd swap for an A8 LSD SS diff and be done with it!
Hyper Blue/Ash Gray
A8
Dual Mode Exhaust
Navigation
Old 12-27-2022, 11:40 AM   #9
tlr3715
Drives: 2002 Z28, 2023 1LT RS Redline
I have the lsd on my V6 manual. Seems to work much better than the GM Torsens from the last and the “mechanical” lsd from the Mustang GT I came from. Anyone know what kind of lsd they use for the non-electronic lsds?
tlr3715 is offline   Reply With Quote
3.6 v6, differential swap, swap
