Black lightning
Bad gas or oil low or both
Today after getting gas my Z started acting weird getting a flashing CEL when I WOT and going away seconds after I let off. It continued this basically all day even while at the track. So I’m thinking it’s gotta be the gas (probably) so when I got home I. Decided to check the oil which I really don’t ever do unless the low oil light comes in (if the Z has one) so I checked the oil as Damn!! It’s low!! (If it’s that level hot as hell cold is probably LOW LOW)
My car hasn’t had ANY problems until after getting gas. I’m now starting to think the CEL was in regards to the oil level??? Needless to say I’m getting oil before starting her AGAIN. In the picture I’m sure some of the oil dripped down on stick it was barely past that first line
[ 2021 Camaro ZLE 10 speed
#2 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 CT4-V Blackwing Join Date: Sep 2013
2013 Camaro SS 1LE - Black - M6 - Sold 2016 Camaro SS - Mosaic Black - A8 - Sold 2017 C7 Stingray - M7 Coupe - Sold 2019 C7 Grand Sport M7 Vert - Sold 2021 Camaro ZL1 - Black - A10 - Sold 2019 Tesla Model 3 2022 CT4-V Blackwing - M6 |
#3 | |
Black lightning
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '21 ZLE A10 Join Date: May 2012
relax...in the hash marks is "safe". When you check it cold, it will likely read higher as oil has settled to the pan. A low oil situation will not cause a flashing check engine light but the DIC would alert if the oil was low or oil pressure was low. I know this as I had the infamous oil pump failure in my '17 ZL1...no check engine light but alerts indicating to "reduce engine speed" then "stop engine" because of low oil pressure. Scan the car for a possible stored code as many people get knock sensor codes or random misfires causing the flashing check engine light.
![]() ![]() ![]() ![]() Drives: 2018 Camaro ZL1 Join Date: Aug 2018
The cars do lose oil when driven hard, especially at the track. As mentioned you generally wait up to 30 minutes before checking the oil so that it has time to settle.
A hot engine will read much lower than a cold engine. As long as it's in the hash, you're OK but if that reading was from waiting at least 30 minutes then you need to add a quart or so. If it was bad gas, you'd know. I had bad has my Tundra once and it wouldn't start the engine immediately. It would take a extra 2 or 3 turns of the ignition. Plus I had a CEL on the whole time once it did start. For the check engine light, what else was going on at that time? Were you coming out of a corner? Were you WOT down a straight? How much has was in the car at the time? Did it feel like it was reducing power? What mods do you have or are you stock? You could have air in the supercharger coolant. But you might be able to go to Autozone and let them do a free scan to see if the codes are stored in the car. |
![]() ![]() Drives: 2017 ZL1 Join Date: Jan 2017
Agree, there is tons of oil in that car, I wouldn't be worried about low oil.
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
From the pic of the dipstick looks to be about a quart low. Mine was like that 2 weeks ago and I added a quart and was good to go. I did check it when the engine was cold from overnight sitting.
#8 | |
Black lightning
#9 | |
Since you're running E and have headers, you're tuned. Maybe something in there didn't like the mixture. I'd say run through maybe 2 full tanks then try to do some WOT pulls on the street to see if it goes away. Did the car start ok while you were at the track? Did it hesitate or take extra time to start? Just wondering. |
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
Flashing CEL is a misfire, I had this recently immediately after a fillup (half tank at the most) on BP 93 on a WOT pull. I hooked up my OBDII scanner and it had no codes and the light had gone out <1 min after illuminating. But it caused me some concern. Temps were super cold that day and I figured it got a gulp of 10 degree air that I didn't like. So far so good, no reoccurance.
#11 |
This is bad:
Decided to check the oil which I really don’t ever do unless the low oil light comes in |
#12 |
These engines hold 10 quarts of oil, so being down a quart wouldn't cause an issue.
Flashing CEL is a misfire as mentioned above. I would check the plug wires again. MSD wires are notorious for being difficult to "click" into place. That being said with a flex sensor I wouldn't go out and floor it right away after getting fuel. If the alcohol composition changed it needs 5-10 minutes of drive time to adjust the fuel trims.
#13 | |
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
#14 |
Black lightning
Agreed
