12-14-2022, 04:00 PM | #1 |
Drives: ‘17 2ss. 416ci stroker, proc Join Date: Jul 2020
Driving modes “randomly switching”
My 2017 has been randomly scrolling through the driving modes without touching the switch. Anyone else having the same issue?
12-14-2022, 04:44 PM | #2 |
Drives: 2017 1SS 6spd Join Date: Jan 2011
Have you got a manual trans? I know due to the location of the mode switch and traction control, I'll accidentally change modes or shut off traction control. I've got a 6 speed with a Hurst shifter and with cooler weather seems just the weight of my jacket cuff will change it without me being aware.
12-14-2022, 05:36 PM | #3 |
Drives: 2018 2SS 1LE Black Join Date: Aug 2018
Disconnect the switch and see if it continues. Bad switch, body control module grounding issue.
12-14-2022, 08:30 PM | #4 |
Drives: 2024 Riverside Blue 2SS 1LE Join Date: Mar 2016
Going through the same issue with shifting with a coat. hit the traction control and mode at least once a trip.
12-15-2022, 07:43 AM | #5 | |
Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | K&N Typhoon CAI | LT2 Ported | 95mm ZR1 TB | LSA crankshaft conversion w/modified crank gear | LS1 thrust bearing | LS MSD Plug Wire Set | BTR Stage I Cam | ARP Rod Bolts | Delphi Lifter set | NGK LTR71X-11 spark plug set | DOD Delete | VVT Limiter | ECM, TCM & E85 | Retuned by: Justin L. | Dyno: 510 rwhp 472 rwtq | Best 1/4 Time: 11.639
12-15-2022, 09:29 AM | #6 |
Drives: 21 ZL1 Join Date: Feb 2022
Its you hitting the switch.
12-18-2022, 07:41 AM | #7 |
It does it with both hands on the wheel. It’s scrolls through the settings without selecting one.
12-18-2022, 07:55 AM | #8 |
I’m going to start checking my all my grounds. The issue started after i had the motor and trans out of car.
12-18-2022, 11:40 AM | #9 |
Drives: Your Mom Join Date: Jan 2022
12-19-2022, 07:50 AM | #10 |
Electrical Engineer
2023 1SS A10 Black NPP/C2U/H72 - Daily Driver
Historically an Accord and Camry owner with self-performed maintenance/repair. 1100: 5/3/22 . . . . . . . 2000: 6/25/22 . . . . . .4000: 8/17/22 . . . . . . . 6000: 9/10/22 Daily Driver mileage update: 22k mi. @ April 2024 New Engine @ 22,600 Build Log: https://www.camaro6.com/forums/showt...6#post11353116 |
